Question about Smeg FC40RX Bottom Freezer Refrigerator
Freezer is very frosted up. Do we have to switch off fridge and defrost all?
  • Smeg Master
  • 43,501 Answers
Yes, that is the best way to do it...
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorFreezer is very frosted up. - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Aug 07, 2010
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Belling bk29 fridge freezer. freezer working but fridge not working. compressor running, thermostat set to 5, light working ok, defrost switch off.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 08, 2011 | Refrigerators
The bottom freezer has exceesive frost, and is not cold enough. I tried to remove the frost, it will work for about a week afterwords. Help
Really when the fridge frost very excessively there is less cold.
You have to regularly set up defrost setting if your fridge has automatic defrost.
Or your fridge has manual defrost then defrost it twice a week.
To minimize excessive frost, set the temp control setting to just mid- position.
Good luck.
Jul 01, 2011 | Amana ARB8057CSL Bottom Freezer...
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
My frost free fridge freezer has stopped working(beko) the fan inside the freezer is consyantly on the food in the freezer has defrosted and the element at the back is usually hot and now its cold
Please checck to see if your thermostat lines are in order or if some of the connecting wires are damaged bby frost. First of all switch off the fridge and allow all frost to clear. then check for the fan circuit, the auto defrost timer circuit. Now after few hours switch on the fridge. Check to see if the compressor is running the back side is getting warm and the freezer is cooling. If not check if the compressor is pumping well or being short of gas-- get help -. If not the timer could be the culprit as after the cooling takes place the fridge does not defrost. Check this out and the fault is confirmed if your fridge works fine now. Hope you try. Good day
Aug 11, 2010 | Refrigerators
Eaton viking fridge model RF1717
hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Oct 07, 2008 | Viking Refrigerators
Fridge/freezer : freezer appears to be working okay but fridge is frosting up despite changing the temperature dial
hi. thanks for the question .You mean the freezer is frosting up. not the fridge . check the defrost timer. and termination switch. and defrost heater . one of those three parts has failed thanks the appliance doc
Oct 01, 2008 | Hoover Refrigerators
THE FRIDGE FREEZER CONSTANTLY MAKES A GROANING SOUND AND NOW EVEN THOUGH ITS FROST FREE THERE IS FROST STARTING TO APPEAR ON THE BACK WALL OF THE FRIDGE
You could have one of two problems- 1) The defrost timer has failed OR 2) the defrost heater has failed.
Switch off fridge, open back panel check continuity of defrost heater. If it checks out OK you need to replace the defrost timer.
Jul 24, 2008 | Refrigerators
Maytag french door fridge no cooling in fridge section
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
Jun 28, 2008 | Maytag Refrigerators
Smeg FC40RX Bottom Freezer Refrigerator Logo
305 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Charles T Nevin
Charles T Nevin
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
