Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Riding my tractor, switched on the headlights and everything died. Unable to start - no electrical power???
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Probably there is a short in the headlight circuit, so when you activated it, it blew the main fuse for the tractor. It's part number 26 in this diagram. Lift the hood and find the fuse. Take it to an auto parts store or radio shack and buy a pack of them. Be sure your headlights are off, install the fuse, and you should be fine for daylight mowing. If you want to find the short, pull out both headlight bulbs and see if you can turn out the switch without blowing the fuse; if this works, then it's just a shorted bulb. If it blows the fuse without bulbs in, it's the wiring -- look for a place where the insulation has rubbed off the wire. Good luck! Please rate my solution if helpful, thanks.
Posted on Aug 07, 2010
John deere stx46 engine dies when mower engaged
you do need to be sitting on seat for this to run , if you are but it still dies then you'll have to invesigate switch out they do go bad sometimes
May 23, 2014 | Garden
John deere 111 dies when go to move it
I just got done with real similar prob my at first would start not rev up very well could drive it fine try to engage pto it die i checked everything carb back fire prevention was good cleaned carb seat switch checked out fine ignition switch had little corrosion changed it nope then it started to die after i started it and let out on foot pedal thought that was it checked with wires hooked up still get different readings each time unhooked switch it checked out fine then the seat switch would give me different readings on meter took it off test again fine was ready to have a fire sale on this pos i started to go through every electric con. Clean and make sure contact were good noticed a small crack on ignition switch female plug then found same on pto female plug got new plugs put wires in fixed everything
Jul 02, 2013 | Garden
Riding my ttr 250 Runs fine then just dies when ded no headlight starter or anything. I wait 10 mins kick it and starts rides about 2 Mins and dies again what could it be?
Maybe trash in your carb. Take the carb off and clean every hole you can find. Put it back together and reinstall. Should work fine.
Jan 22, 2013 | Garden
My 54" Poulan Pro riding mower dies when the
battery weak replace or charge, mower has electric clutch which pulls amps from battery
Jun 26, 2011 | Husqvarna 24HP 54" Yard Tractor ()
When i turn key on nothing happens , no head lights come on or anyting, battery is good.i hosed it off the other day with it running, when i turned on pto switch it died then nothing.
Headlights may not run on the battery, but rather the magneto/alternator.
Make sure all of your safeties are set: Transmission in neutral, Cutter blades set to OFF, Brakes on and locked, Rider in seat.
Then try to start.
Gary
May 01, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Mower will not engage when switch for electric electric clutch is pulled up into on position
could be safety switches faulty or sticking,usally 1 under seat, and 1 by the catcher, pto toggle switch maybe faulty, if battery is low there won't be enough power for the clutch to engage. I would jump the clutch to make sure that hasn't died first cause that is the costly part.
Jan 24, 2011 | John Deere 195HP Hydrostatic 42" Cut...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
No power at all.
Check electrical continuity from battery to starter
Jun 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
187 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
