Question about Frigidaire Washing Machines
Replacing the boot ( bellows) - 134380700 - Frigidaire Washing Machines
What are bellows boots on a honda
the bellows are the the plastic tubes that protect the inner tie rod end/rack from dirt and water. If there is fluid coming out of the bellows than the rack is leaking. The normal repair is to replace the rack with either a remanufactured or new rack and pinion.
Dec 29, 2011 | 1998 Honda Accord
I pulled bellow boot out from door with the bellow clamp
you can try to do it from inside but difficult if you never have done it
Jan 09, 2010 | Kenmore HE2 Plus Front Load Washer
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I just had my CV axles replaced on my 96 maxima. I tried to get it inspected and was rejected for the bellow boot. Does this have anything to do with axles and how much is THIS one going to cost me? Please...
The bellows boot is the rubber accordian like shaped piece that protects the axle from water and debris entering into the axle, which is covered in grease, and prevents the axle from premature wear. This should have been take care of when the CV axles were replaced. (if it is indeed the bellows boot for the CV axle.)
Jun 15, 2009 | 1996 Nissan Maxima
What do bellow boots do?
all they do is keep dirt and water from getting into the steering unit, they are seals, if your steering is acting up it is to late, the damage has been done by the torn boot.
Feb 19, 2009 | 2002 Mitsubishi Lancer
How do I replace the kenmore he2 bellow?
door boot not eady to install,, if you can but machine on a 45 tipp back and place 4x4 wood to hold in front it has a clamp remove ,, now there is another clamp once u can remove boot ,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
I ordered a new bellow for my whirpool duet front loader washer. where can i find out how to replace the part. when the part came from the internet, there weren't any instructions. i want to replace the...
ok karl remove front spring around front outside of bellows pull bellows away from inlet tube on upper right corner is a screw 7 mm i believe although 9/32 will work losen screw and remove band through front opening remove boot reinstall in reverse ..have fun getting bellows around drum opening takes a little patience and putting outside spring back on can break a nail
Jun 18, 2008 | Washing Machines
How to replace the door bellows seal ?
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Mar 12, 2008 | Washing Machines
Washing Machines Logo
290 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
