Question about Oki Electric Industry C3300n Laser Printer
My c3300 oki printer wont print. in the past I have had a 'drum life' warning - black so I replaced it, but the message always continued , though the printer worked. Anyway just rcently got a drum and toner life warning again for black, so I changed the toner cartridge - but message has not cleared despite switching off and cancelling print job. Orange warning light on. Owner intervention coming up as a message when I click the prnter icon to check status - but I don't lnow what to do. Help appreciated very much! Linda
leroyal
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
  • 13 Answers
SOURCE: I have a new OKI B410d printer which is givng
It is more than likely that you have an incompatible toner fitted to the drum unit. Either a generic cartridge or b430 or b440 cartridge which is not compatible with b410's. Beyond that it may be a faulty drum unit. Hope this helps.
Posted on Sep 14, 2009
Shah_Sheh
  • 81 Answers
SOURCE: how to reset black drum counter OKI C3300
The consumable counters are aotomatically reset on the OKI C3300n models.
If the printer has a message displayed or you need more assistance leave a comment
Posted on Sep 15, 2009
anantakumarj
  • 330 Answers
SOURCE: user intervention required
check the connection and restart the printer .........
if not working means reinstall the printer driver ..........
Posted on Oct 30, 2009
hari007_in
  • 138 Answers
SOURCE: Our Oki C3300 is printing faintly on the lefthand
try to reinstall with all the drivers,, and make sure, there are no virus,,, make sure and check with antivirus..
Posted on Nov 10, 2009
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
Okidata c9650 printer. technician told me to replace transfer belt in my unit because i was having an issue with the color print quality. It had a light streak running through it and the top of the page...
That message is indicating that you need to replace the black drum which also may have been what was causing your origanal issue. Whenever you have a print quility issue print four seperate documents each document using one of the four colors (black, yellow, magenta, cyan)used by the printer. If the problem only shows up in one color then that is where the problem is coming from.
Jan 21, 2011 | OKI C9650HDN Led Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Oki C5450 error message
The figure after the K drum Life tells you how much life there is left on the BLACK (K) drum. C indicates Cyan, M indicates Magenta and Y indicates Yellow.
Go to the USAGE MENU and look at the K DRUM LIFE setting. This will be a 2 digit percentage value. As you have just seen the message appear this will mean that the drum life remaining is ....whatever the 2 digit value displays.
The life expectancy of a drum is approximately 15,000 pages.
Jun 08, 2009 | OKI C5400 Laser Printer
I have an Oki C3400 that wont print
Could very well be the sensor window. I suggest looking at the side of the drum on the right side and pushing a q tip into the opening. heres an older model thats sort of similar instructions. http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
Also you can check the exact error code here. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Dec 10, 2008 | OKI C3400n Laser Printer
Oki c5500n drum reset
To get the OKI C5500 to keep going (without opening and closing the lid constantly) in spite of toner cartridge & drum life messages:
1) Turn off printer.
2) Hold down "+" and "-" buttons at the same time, and keep them held down while turning printer back on... continue to hold until the word "OKIUSER" appears.
3) Use "-" button to scroll down to "FUSE KEEP MODE".
4) Press "Enter" button, hold for approx. 10 seconds, then release.
5) Press "Enter" button again, followed by rapid release and repress with hold for approx. 10 seconds.
6) Release "Enter" button, then press and let up one more time quickly.
7) You will see "INITIALING" and then "ONLINE" messages.
If you currently have an error message for toner cartridge life, the message will continue to be shown until after you've sent one print job, and then it will usually disappear for awhile. It will stay gone for longer if you have your printer set up so the toner sensor is turned off.
If you currently have a error message for drum life, it will continue to appear, but you will still be able to print.
Beware that you will have to keep a closer eye on print quality (since you are no longer relying on error message to tell you when your toner cartridges are in need of a replacement or refill, or the drum truly needs to be changed or refurbished).
Please note that anytime you turn the printer off, you will have to go through the whole process again when you turn it back on. It doesn't take long though, and will quickly become habit whenever turning on your printer for the day!
Good Luck.
Apr 08, 2008 | OKI C5500n Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual: http://www.feedroller.com/Store/Service%20Manual/50_53_5600.PDF
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
Message on printer
Your printer has counter on it that keeps track of the number pages that have been printed with it. It is warning you that the drum unit is coming close to the end of it's rated life. Order a black drum unit and have it on hand. Some time in the near future the printer will stop operating until you install the new drum which will come with instructions on how to install it. If you order it now, you will avert a "Crisis" later. Ed
May 22, 2007 | OKIDATA B4350N LASERPR 23PPM ETH-W/ PS BLK...
Oki Electric Industry C3300n Laser Printer Logo
87 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Fix It Fast...
Fix It Fast...
Don  Farrell
Don Farrell
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
