Question about Dell Inspiron B130 Notebook
4 beeps but won't come on - Dell Inspiron B130 Notebook
  • 700 Answers
4 beeps of equal lenght suggest that system timer is not working, you need to change cmos battery on your laptop. If you are game, that is how you change CMOS battery on your laptop:
1. Switch off computer, remove power cord and battery, turn computer "proper" side up, open and press power button to discharge
2. Open display in full (180 degree), there is small indent on hinge cover, close to hinge on right and left side, slide in little flat (screwdriver will do) and lift right side up, slide cover towards left and remove it, do not lift on both sides simultaneously!
3. Remove two small screws on the top of keyboard, lift keyboard slightly up and towards you, be aware that keys and tabs on keyboard are fragile and difficult to replace! Lift keyboard connector and slide the cable out. it is not really necessary to remove keyboard, but it easy to replace without keyboard being in the way.
4. Find coin battery, disconnect cable from socket by pulling it gently towards the battery. Remove cable from guides and battery from it's seat
5. Replace battery with exact same type, put it back into it's seat, guide wire through and connect it back to the board.
6. Re-connect keyboard cable, place front keyboard tabs into palm rest and screw back two back holding screws
7. slide in left side of hinge cover into place, press from left to right till it click in place.
8. Re-install battery and power cord, switch on computer, re-programe BIOS ito previous state.
This should solve your CMOS batery problem. Of course you can send your laptop to the technician but that will be no fun at all... ;-)
Posted on Aug 07, 2010
Won t stop beeping
if it's just continuously beeping, then you may have a shorted control board. This isn't an error code, so if it keeps beeping, you may need to replace the control board itself.
Dec 18, 2013 | GE Dishwashers
HP desktop computer makes many long beeps i a row and won't turn on
Those beeps are warning beeps look up what the beeps mean for your machine.
Jan 02, 2013 | HP Computers & Internet
Dell inspiron530 won't boot and beeps four times stops and beeps again
The Beeps are a beep code 4 means you have a ram read/write failure. Or a possible motherboard failure in that case you will need to contact Dell or replace it yourself.
Oct 01, 2012 | Dell Inspiron 530s Desktop Computer
My ups won't stop beeping
The beeping on your ups is the sound of an alarm it will come on when starting up due to slow start circuit, there are a reset switch on the front display press once and beep will despair.
Aug 19, 2012 | Computers & Internet
I have a HP a6300f computer. It won't boot. Once I turn it on, it beeps for 17 seconds, is silent for 10 seconds, and follows by another beep for 17 seconds. I'm not sure what the problem is.
The duration and time of the beep codes is going to tell you what the problem is..
Here is the hp page that has the beep code information.
HP Beep Codes
The specific beep code info is towards the bottom.
Hope this helps
Aug 29, 2011 | Computers & Internet
Computer won't boot and beeps: BEEP pause BEEP BEEP BEEP
In case you have AMI BIOS, it is a computer RAM (memory) related issue.You can remove added memory, reseat memory, swap memory location or try memory from other computer
Jul 05, 2011 | Computers & Internet
Player won`t read
turn console onto standby and leave a min
then hold button in till it beeps 3 times and release
then do this again it will beep 3 times last one being double quick beep
a menu should appear
click on the one that says files this will restore your lens reader
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Dell Inspiron B130 Notebook Logo
97 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
