Question about Dell Inspiron 530 Desktop Computer
My dell beeps 4 times when plugged in, but won't come on.
  • joecoolvette
    joecoolvette Aug 07, 2010
    Don't Forget - FIRST. Computer unplugged from power, observe Anti-Static Precautions, BEFORE you reach inside your computer! (Work on a table)
  • 700 Answers
4 beeps of equal lenght suggest that system timer is not working, you need to change cmos battery on your computer. If you are game, that is how you change CMOS battery on your computer, takes about 5min, required tool is phillips screwdriver:
1. Switch off computer, remove power cord
2. Remove left hand cover (this is cover which is on lyour left while you stand in front of the computer)
3. As you look at computer "gizzards" on right hand on the motherboard you will see silver battery about nickel size, it is located in this computer about three finger width from the bottom of the motherboard and about 1 1/2 finger width from right edge of the motherboard. Unlatch it and remove it. Purchase exactly same battery, be it in drugstore or hardware store.
4. Slide in new battery, + is up, towards you.
5. Mount back side cover
6. Re-connect your power cable and start the computer
You most probablay will need to re-program BIOS as all information is lost when this particular battery die.
This should solve your CMOS batery problem. Of course you can send your laptop to the technician but that will be no fun at all... ;-)
Posted on Aug 07, 2010
    New Friend:
I went and got a new battery for the old battery and it still beeping four times what do I need to do now
Posted on Oct 05, 2014
Dell inspiron530 won't boot and beeps four times stops and beeps again
The Beeps are a beep code 4 means you have a ram read/write failure. Or a possible motherboard failure in that case you will need to contact Dell or replace it yourself.
Oct 01, 2012 | Dell Inspiron 530s Desktop Computer
My Dell Inspiron 530 won't start. 4 Beeps, Soild blue light.
According to Dell this is a RAM issue. You can find a list of diagnostic Beep Codes here. Also be sure to inspect the capacitors on your motherboard. If you notice any of them leaking or blown then that is your problem.
If you have extra RAM lying around then swap it into your PC and see if you're having the same problem. If not, pull out any unnecessary RAM just to test it. There are four RAM slots on this PC and you should be able to use any one of them. If your PC turns on then you can isolate which chip is giving you problems. Keep in mind RAM is ideally installed in matched pairs.
If you only have one RAM chip in your computer then I'm afraid you will either have to buy another one or borrow one from a friend to test. Shouldn't be too expensive anyway.
Jul 24, 2012 | Dell Inspiron 530 Desktop Computer
My dell inspiron beeps 20 times at sturtup
I wonder if you have a keyboard issue. Most times the constant beeping means the keyboard is bad, but it doesn't normally boot or revert back to 5 or 4 beeps.
May 08, 2012 | Dell Inspiron 6400 Notebook
Why won't my laptop start up?
according to the manual a series of 4 beeps indicates a "RAM read/write error". Do you know how many sticks of memory you have in your laptop?
Feb 18, 2012 | Dell Inspiron M5030 PC Notebook
Lenovo 3000 J Series won't boot up. It beeps 4 times and does nothing.
the only beep code i can find for 4 beeps is a keyboard error. if you're using ps/2 you should make sure you haven't put the plugs in the wrong ports. i found the information here: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_pdf/41t3751.pdf
page 75
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 16, 2012 | Lenovo Computers & Internet
My dell mini 1012 won't boot up, just beeps 8 times over and over again.
Trying unplugging the computer, remove the battery, open the memory door and remove the memory, clean the memory contacts with a clean dry soft cloth and then replace. Replace the battery, plug in the computer and try again. Sometimes residual power builds up ...
Aug 08, 2011 | Dell Inspiron Mini 1012 Netbook...
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
Memory not being properly identified or used
4-3-1
Memory failure above address 0FFFFh
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Oct 12, 2010 | Computers & Internet
Dell Inspiron 530 Desktop Computer   Logo
2,738 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
