What do do when it does not squize - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewhat do do when it - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 07, 2010
  • 10,865 Answers
If your clothes are loaded with water the problem is that it is not spinning the clothes to a fairly dry state. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Gasoline will not enter squize bulb
The squeeze bulb has two lines connected to the gas tank:
One is the return line. This must not be blocked or gas cannot flow.
The other is input. If this is missing, broken or leaking air (usually a dry joint caused by old brittle tubing) it is time to replace the gas line.
Another problem is if the bulb itself. If it is crackd or not seated properly it will leak air and not fill.
Check all these in turn and replace tubing and bulb as necessary. It is possible to buy a generic fuel line kit - or take it to your local workshop.
Aug 14, 2013 | Hitachi Garden
Fuelpump wont come on
You need to get a fuelline disconnect tool. They are sold in a set with different sizes . The set costs under $20. You can buy them at any auto parts store.
Nov 25, 2011 | 2002 Lincoln LS
I have the Ladies Wall Street watch with the beige color leather strap. A red velour tracksuit rubbed some red on the band...how can I get it off? Thanks for your help! NancyMacNeill
Hi nmac1009
The most common way to remove any coloured spot is to gently rub it with some spirit or petrol.
You can take a earbud. Dip it in gasolene or petrol.
Squize it.
Then gently and very carefully rub it on the red spots.
Note: Be very careful while doing this.
Better you first check that it does not remove the original color of the leather strap.
Then only go ahead.
Hope this helps.
Jan 28, 2011 | Stuhrling Watches
Brother DCP 330 Paper squizes and jam
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Dec 22, 2010 | Brother DCP-330C All-In-One InkJet Printer
Turned on the tv, made a loud noise and tv has no color! Samsung HL-R6168W
The color wheel has shattered. Probably a bp94-1579 or such. About a 300 dollar repair or so in home, not hard to do for a decent tech.
Oct 08, 2009 | Samsung HL-R6168W 61" HDTV
Charging MP3 Player
Usually ya simply plug it into the USB port, that "Charges" it up.
Have a squiz at a ya manual.. see if it tells ya there?
Jul 28, 2008 | SanDisk Sansa c200 MP3 Player
Freecom 500gb storage drive
If the fuse has blown then I am almost certain the Drive would be Kaput! sorry..
It may be possible to recover data from ya kaput drive, very difficult and expensive but do-able..
Ya probably should take it to a reputable shop let em have a squiz..
Jul 24, 2008 | Freecom (24358) 160 GB Network Hard Drive
Washing Machines Logo
Top Washing Machines Experts
