Question about Epson AcuLaser C1900 Printer
?????? ?????? service req. D1020- - Epson AcuLaser C1900 Printer
Service req e 406 -
I'm going to assume you have an epson 406, and that you got a "service req" error. Means, "service required". There should be a code, too, that might tell us what service is required, but without that, we can do little for you.
Jul 15, 2016 | Office Equipment & Supplies
Service req 0001001C
SERVICE REQ - 0001001C - FS origin (Suction fan shutter home position) error
Jan 18, 2013 | Epson Stylus Pro 10600 InkJet Printer
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Audiovox D1020 will not power on?
I have a unit with a broken screen that I am trying to find a replacement for. (one with a good screen) Please email me and let me know if you are willing to sell yours. Thanks
buckeyevcr@aol.com
Feb 26, 2009 | Audiovox D1020 Portable DVD Player
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error in printer
" Service Req E 0003" means that your printer needs to be serviced. Pls contact your service provider.
Jan 27, 2009 | Epson EPL N1200 Laser Printer
Stripes on the right side of my Audiovox D1020
Hi..
If the player does this on any DVD then, I'm sorry to say, the screen is broken and it's cheaper to buy a new one.
Jan 08, 2009 | Audiovox D1020 Portable DVD Player
Horrible Static on both headphones and van speakers when playing
Hi...
The most probable cause it broken solder connections on the headphone/ext speaker jacks.
If you know someone who can solder fine detail parts...have them try.
I dont know what a TV shop would charge but it DOES need fixing
Nov 20, 2008 | Audiovox D1020 Portable DVD Player
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
Problem with white screen
Similar experience with a D1020. A very small component on a surface mount PCB developed a cold solder joint and eventually came off altogether. If you have a small low power soldering iron and experience with very intricate soldering, you can attempt a repair. Do not imagine that a repair shop can repair for a reasonable expense.
Sep 06, 2008 | Audiovox D1020 Portable DVD Player
Epson AcuLaser C1900 Printer Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
