Question about Garden
I blew the switch on my shop fox W1714 when I wired it for 220. Can I fix the switch or do I have to buy a new one?
  • 10,865 Answers
That switch is shorted out and must be replaced. J.
Posted on Aug 07, 2010
Brake lights troubleshooting
You connected up the brake light switch incorrectly, the new switch is faulty, or you blew the fuse by shorting out the wires while fixing the switch, or both tail lights are burnt out, or if the vehicle has benn accident damaged, the shop forgot to attach an earth on the taillight assembly.........
Jul 04, 2014 | 1995 Nissan Pathfinder
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Nov 04, 2012 | Washing Machines
Hayward super pump wired to switch diagram
sounds like 220 volt if using a switch must be for 220 volts usually pumps wired for 220 volt blue wire to one side of switch terminals then new wire to pump L1 lug the other side of switch gets the red wire going to other side and new wire to pump from switch to L2 and green to case or ground make sure motor is wired for 220 volt on back
Dec 06, 2017 | Pool & Spa
My 88 fox wagon has blown the radiator cooling hoses 2 times, second time was after i replaced first hose, it ran for 20 min and blew another hose. is it the thermostat?
It could be. More then likely it is a head gasket. You need to bring it to a shop and they can test if there is exhaust gasses leaking into the coolant system. If this is the case it will be much more expensive and will require your car to be unusable for a little longer. If it is a blown head gasket it is not good to continue driving the car. Have it towed to a shop.
May 06, 2011 | 1988 Volkswagen Fox
I recently purchased a Delta 50-760 Dust Collector and was told I could convert the motor to 220 volt. I presently have a 220 volt saw and wanted to run them both on 220 so I looked at the book and it said...
I am currently in the process of doing the same thing. Look at the inside cover of the switch case. This is where the capacitor is housed and is attached to the motor. On the inside cover there is a wire schematic. Not a very good one. I have yet to fully trace out the current wire connections. Don't forget to change your plug. You do not need to replace the switch, just rewire input power to the motor.
Jan 13, 2011 | Delta 50 - 760 1.5HP Dust Collector
Vw fox lights do not go on despite changing fuses and relays
Try testing the switch and then the relay. Usually its the switch. Use a flat screw driver to pull it s out of there connector. Use a jumper wire and shop manual to jump the terminals and see if the lights come on. If they do its the switch.
The relay you check for continuity and resistance.
Aug 12, 2009 | 1989 Volkswagen Fox 4 Door
High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Mar 11, 2009 | Garden
Plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Nov 04, 2008 | Remington HC-600 Hair Trimmer
No power to fuel pump or to pump fuse at fuse block
You can get wiring diagrams from autozone.com -- they have parts of repair manuals online. I have the smae problem but the person I got my 88 fox gl from wired up a switch going to the fuel pump that you have to leave on while driving. I"m probably giong to fix this soon. It looks like the wire powering the fuel pump relay comes from the ignition switch. So if the pump side of the relay is good, but aren't getting power, you may want to see if your ignition switch isn't providing power on one wire, going to the fuel pump relay.
Jun 24, 2008 | 1990 Volkswagen Fox
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
