Question about Sony VAIO VGN-N250N/B Notebook
I HAVE SONY VAIO 120GB PEN DRIVE WHEN i FIXED IT INTO MY COMPUTER I CANT FORMAT IT
2 Suggested Answers
pankaj_dic
  • 1252 Answers
SOURCE: 120 gb pen drive copying problem
this is due to the virus problem , go to folder option check view hidden files options, also check show protected files option there you can see all your files on pendrive, scan you pen drive and system to a updated antivirus
Posted on Oct 24, 2008
Cant format my son
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Always take precautions while using pen drives on other computers. See the some of our posts below on protecting your pen drive from viruses:
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chip corruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
Dec 28, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
I have the same problem. I am having a sony vaio vgn-nr120e and my hard drive crashed. Please let me know the exact hdd to replace my sony vaio hdd. I am a novice in computers. I find somethings so...
I've replaced my Sony Vaio VGN_160 with a 120gb Seagate Momentus 7200rpm, 16mb cache 2.5" Sata drive. I would think all notebook SATA drives should be compatible. The 7200rpm drives cost the same as the 5400 and it only uses something like 5% more power. (I read that in a forum so I can really say if it's true.)
I did notice a performance boost from the faster and higher cache drive. It was enough to get my 4 year old Vaio another 12-18 months of life before I get a newer one. And you CAN install Windows 7 (x86 since my Vaio is a core duo and not 64bit compatible.) Yours should be able to take Win7 64, unless of course you like Vista.
Once you remove the stock drive from the drive cage, it's a matter of putting the new drive into the cage and then reinserting.
I would suggest you format the new drive before you replace it. I had the Vaio back together without formatting, and Win7 install DVD was not able to find the drive until I formatted it on my desktop. The Sata and power connector are standard so it was easy to do.
Oct 18, 2010 | Sony VAIO VGN-NR120E/S Notebook
I have a fake Transcend pen-drive of 32GB.Its property is showing31.2GB free space.When Iam putting any data into it, is showing until i pull out my pen-drive.When i pull out my pen-drive and again when i...
So you know the little errors you get when not removing your drive safely? That is most likely the problem. Removing them non-safely can damage them and cause data lost. You may need to get a new drive.
May 22, 2017 | Transcend USA 120GB Storejet 2.5" SATA -...
Sony 4 gb pen drive
Hi friend,
You should scan your pen drive by any antivires because your pen drive have some vires so you are not able to format it...you should try other computer...
With Regards
Dec 31, 2009 | Sony Electronics - Others
Pen drive show 0 bite. But my pen drive is 8 GB. How i solve my problem?
Insert pen drive, right click on corresponding drive, then select format
format should fix it if the drive is not physically damaged.
Also, did you set your flash drive to speed up your computer or use as additional ram? if so that might also be an issue.
Oct 06, 2009 | Sony VAIO VGN-AR720E/B Notebook
How to install vista themes on sony vaio laptop(120gb HD,1gb mem)
windows vista themes sony vaio windows xp professional for mulitple computers ... best way to install windows vist
www.videocodezone.com
regards
murali
Dec 08, 2008 | Microsoft Windows Vista Ultimate Edition
Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Nov 05, 2008 | Sony VAIO PCV-RX500 PC Desktop
Oct 24, 2008 | Sony VAIO VGN-N250N/B Notebook
Pen drive not working
If your usb port is working properly your computer should pick up the the pen drive as soon as you put it in the usb port if not goto add and remove hardware and check to see if the diver is up to date .hope this works for you let me know ok
Feb 16, 2008 | Electronics - Others
Pen drive problme
you need to reformat the flash drive. right click, click format (assuming Windows XP), then format with the default options (do not quick format).
If it will not format, it is corrupted, in which case it is worthless, for all purposes.
Jan 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sony VAIO VGN-N250N/B Notebook Logo
176 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
