Question about Seagate Technology - Momentus 7200.2 ST980813ASG - ST980813ASG-25PK 80 GB SATA Hard Drive
External harddisk in not working - Seagate Technology - Momentus 7200.2 ST980813ASG - ST980813ASG-25PK 80 GB SATA Hard Drive
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Iomega 2 tb ego dead
This is an external HDD, right ? In such case it's good to realise, such devices are a combination of an external USB enclosure and an internal SATA Harddisk. Maybe the harddisk is still OK, but the PCB (print with all tiny electronic components soldered at it) is defective. In such case you can overcome your problem by simply buying a new USB enclosure (even non-name will do) and put your harddisk in it.
To check if the harddisk is damaged, you should remove this by opening the Iomega casing and connect this disc inside a PC to it's motherboard. If the harddisc is working again, you're lucky. If not, than even the harddisk is damaged. If this is, and the data at your disc is important, you can try to source a identical harddisk (brand, type and productiondate) and transplant it's PCB. But, I can asure you, this last option is a tricky step.
Oct 16, 2013 | Computers & Internet
Can't find music files i copied / pasted from PC
While copying files to your external harddisk, you must get a pop-up-screen with animation to see the progress. There's however a chance you didn't copy the files to your exernal harddisk but to your local disk into your computer. Try to find the map "My Music" if you're using Windows. Maybe they're located overthere, instead of the external harddisk.
Oct 09, 2013 | SimpleTech Computers & Internet
Will a latop work without main local disk
Yes, and can load from an external harddisk (if your BIOS supported to load from external harddisk).
there's nothing special if you run your computer without a harddisk.
Oct 28, 2012 | Microsoft Windows XP Professional
Dear Sirs, I need the Windows 98 Driver for Western Digital USB External HardDisk 320 GB ? I use COMPAQ Presario with Windows XP to hook up the External Harddisk right know. The External...
Sory to report - from Western Digital support site
Uses SES Drivers
7, Vista, XP
Not Supported
Server 2008, Server 2003, 2000 Server, 2000, ME, 98SE, 98, 95
Win 98 is not a supported OS, for that drive.
Jan 27, 2011 | Western Digital My Passport Essential...
My external hard dirve turns on when i plug it in, but i hear about three-four beeps then it stops but the hard drive is not reconized by the computer.
YOur harddisk can no longer work kindly get another ..
this problem is usally caused by UNsafe shtdown oof the harddisk or when the harddisk falls
Jan 01, 2011 | Computers & Internet
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
250gb Maxtor External HardDisk not responding
How are you connecting it to your pc?  are you supplying external power?
Jan 01, 2009 | Maxtor Hard Drive
EXTERNAL HARDDRIVE 160GB
then due to over voltage in the external ports the harddisk cable might have got burnt or may be where you connect the cable to the harddisk there in the circuit board the pins might have got touched with one another and it may have got short circuited and it might have got burnt away ...
i think your harddisk will be under warranty still as it is new one so just make use of warranty and get the harddisk replaced from where you purchased ...
if you dont have the warranty then the harddisk is dead you cant make it work by anyway even if you contact the technician too he cant help because harddisks cant be repaired once it is removed it is gone ...
i am sure that your harddisk will be under warranty if you have buyed the new one ...
rate my solution
Sep 05, 2008 | Computers & Internet
Seagate Technology - Momentus 7200.2 ST980813ASG - ST980813ASG-25PK 80 GB SATA Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
