Question about Hayward SAND FILTER, PRO SERIES
Water runs through filter and is still dirty - Hayward SAND FILTER, PRO SERIES
  • 52 Answers
Make sure you use the rinse cycle for at least 2 min after backwashing.
The Pool Tech
Posted on Aug 07, 2010
Black water pours out of the heater system into intex spa
Backwash filter system, change filter media if over two years old, flush out heater. Check water clarity going into the filter system, if dirty..., you may have a broken underground line. Check water clarity coming out of filter system, if dirty.., backwash again and check filter media. Also, Heater boiler headers may be rotting.
Apr 10, 2016 | Intex Pool & Spa
Why dose my keurig coffee brewer make coffee with film and oil ontop
Your water tank is likely dirty....try removing it, then remove the water filter, and rinse the tank with dish soap and white vinegar until it's squeaky clean inside. Fill the tank halfway with vinegar and run it through on the small cup size until the water is gone, then replace the water filter and run through a tank of fresh water before brewing again.
Jan 04, 2015 | Coffee Makers & Espresso Machines
How to remove filter on ahd50
if this model doesnt have the removable filter on the middle right side then the filter is not removable by std means and unit will need to be dissasembled for this , Now there are a few reasons for unit to freeze , and yes your right one of them is a dirty air filter . and if its gone too far then a dirty condenser coil as well , also if unit is over three years old then it's possible that due to overheating some of the gas chanrge has gotten out , reducing it's efficency making it run longer with no cool down and freezes up , also if your asking it to remove more water than its designed for (setting to high) it will freeze up as well , std moisture for a home is 70 %rh purchase a small meter to measure this ,(some units have one built in) see how much water you really have ?
Nov 03, 2014 | Haier Dehumidifiers
Pool heater says lo
Say "lo back! Sorry about that. Can you give me a little more info about indications? Has the filter been cleaned lately? A dirty filter often will restrict the water flow enough to where the heater thinks that the pump is not running.
If there is doubt jump the pressure switch inside the heater and if it fires you have a dirty filter or a bad pressure switch.
Jul 04, 2013 | Raypak Pool & Spa
I have a Hayward S310T filter. It's been running 24/7 for over a month. The water does not appear to be clear, even after floccing. How do I tell if the water is being filtered or if the filter is...
Backwash the filter. If the water coming out of the backwash line is not dirty you need a sand change. If the water is dirty you need to continue let the water filter and back washing once a week. Also make sure the six way is on filter and not recirculate
Www.theswimtimeonline.com
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
May 26, 2011 | Hayward SAND FILTER, PRO SERIES
I have an integra shx46a that keeps on running and running for several hours and when it completes the dishes are still dirty. I cannot find the directions for the self diagnosis that In know some Bosch...
most bosch dishwashers have a filter that can be removed and cleaned at the bottom of the tub check filter to see if it is dirty. if the filter is clean make sure your water is hot enough min 120 degrees at faucet may want to run hot water at sink before starting dishwasher
May 12, 2011 | Bosch Integra® 500 SHX46A0 Dishwasher
My (gallery) front load is making my load dirty after the wash. I noticed that if I wash in cold water is not as bad as when I wash with warm/hot water.
Sounds like deposits or dirt coming from hot water tank or line running to washer.Turn off water supplies to washer and remove the hoses from the back to see if the filters/strainers in each port are dirty.If not add a little CLR to the washer and let it run a cycle.Hope this helps.Wouldnt hurt to check the drain strainer either on the bottom of the wassher if you remove the little access panel, might be something in there making water dirty
Jan 20, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Miele dishwasher finishes the cycle with water in the bottom and the dishes not clean
In the bottom of the dishwasher you have a filter. under the filter is a non return valve. it is a one way valve that keeps the dirty drain water from draining back into the dishwasher. if it is dirty or broken, the dirty water that your machine drains out, is running right back in as soon as the drain pump shuts off. this will keep happening and your dishwasher will just spray the dirty water back on the dishes over and over again.
to get to it, you will need to get the water out of the machine. if you have a wet dry shop vac use that. if not, you can bail it out with a cup, and soak the rest up with a sponge. remove the lower spray arm by pulling it up. remove the filter by pulling the handle in the direction of the arrow. lift the filter out of the way. get the rest of the water out of the sump. on the left side of the sump, you will see a silver wire bail holding the non return valve in. flip the bail towards the center of the sump. pull up and out on the non return valve. it has a rubber seal and a stainless steel ball inside. any debris between the seal and the ball will keep the valve from closing all the way, and allow the water to drain back. you can order a replacement if needed, directly from miele. 1800 842 7231.
Nov 19, 2010 | Miele G880 Dishwasher
The intex fp621 4000 pool pump does not seem to be filtering the water. the water comes in and right back out but filter doesnt even get dirty and water seems to go in dirty and come right back out dirty....
Try making sure filter is installed correctly. Push filter down onto foot ring. Install cartridge support on top of filter with gasket into filter and fingers up. If filter is not seated on top and bottom, debris in water will flow around the filter instead of being trapped in it.
Jun 13, 2010 | Intex 4000 GPH Filter Pump
Dishes are coming out dirty, is there a filter?
No filter. Toss two cups of vinegar into the empty dishwasher and run your tap water til it is as hot as it gets. Then run your longest cycle. This will clean the machine. After that always rinse the dishes and always run the hot tap water into the sink until it is hot before you run the dishwasher. Problem solved. J.
Jun 13, 2010 | Dishwashers
Hayward SAND FILTER, PRO SERIES Logo
59 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
