Question about Yukon 100X (6-100x100) (6-100x100 mm)
Yukon yd-100 lens removal for camera fitting seems like thred is broken
I screwed off my lens but when i went to attach my camera mounting the plastic thread that is left seems to have broken is this possible.
  • 22 Answers
When you say lens, did you unscrew the eye piece or the actual lense? because the eyepiece is meant to fit your adaptor for 35mm cameras etc. but the actual front lense should be tightly sealed and thread locked to make your glass (scope) waterproof to some extent and to protect the alignment of the other lenses within your scope. If it is possible your local camera shop may have the ability to re-align and seal your scope, but if not do you have a warranty? and if not even that, if i were you i would align and accraglass your piece back together, it's a last ditch solution that should last for years.
Posted on May 06, 2008
Lens mount is shaky
remove front cover (four screws, one front, two sides, and one bottom), plus loosen two screws holding door latch plate and lift plate up slightly so front cover will lift free (plate has tabs that fit in slots in front cover. Do not lift up too high, just enough to slide cover free). Tighten four metal mount screws and re-attach front cover
Mar 30, 2013 | Canon T70 35mm SLR Camera
Sigma 2x tele converter is loose
I had an issue with my Sigma 1.4X TC where it became loose after several years of use. I fixed min as follows:
On the camera-mount side (where TC attaches to camera) I removed the tiny four screws. Then I very carefully lifted up the metal mount being careful not to damage the ribon cable which is attached to it. I DID NOT complete remove it, I just tilted it up so as not to damage the cable. I then tightened the 3 screws that I found below that as all three were loose. I think that there may be four screws, but I could only see 3 of them without removing the plate further. after tightening the screws and replacing the metal plate and the four screws holding it, the mount was again tight and the attached lens functioned normally.
Sep 20, 2012 | Sigma APO Teleconverter 2x EX DG for SLR...
Dropped my d90. Everything works fine its just the lense wont attach to the mount, I can attach it and it works but unless I am holding onto the lens it just unattaches from the camera
I assume you mean a Nikon D90, not a Canon?
It seems like you've broken the mount on the back of the lens. It should have three flanges. Compare it to the back of another lens. If the mount is broken, you'll need to have it replaced.
If you think you can do the replacement yourself, you may be able to order the part from
I can't give you a specific answer since you didn't specify the lens in question.
Otherwise take the lens to a good camera shop and have a trained professional do the replacement.
Aug 10, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a NIKON DX AF-5 Snikkor 18-105mm lens 13'5-5'6 GED lens That will come off the camera after being attached. Another lens AF-S Nikkor 70-300mm stays on. I dropped camera from 2 ft...
It seems like you've got a broken lens mount on the 18-105mm. Take a look at the backs of the two lenses. You should see the bayonet mount with three flanges. If one or more of the flanges on the 18-105mm are broken then the lens won't stay on.
If you feel up to doing the replacement yourself, you can order the part from
Otherwise have a trained technician replace the mount.
Jun 30, 2011 | Nikon Cameras
How to attach filters to a Rokinon 500mm/ 1000mm Mirror Lens for Canon EOS
For the Rokinon 500mm F/6.3 lens, you can either attach 95mm filters to the front or 34mm filters to the rear of the lens.
For the Rokinon 500mm F/8 lens, you can only attach 30.5mm filters to the rear of the lens.
To attach a filter to the rear of the lens, remove the lens from the camera (or take the rear lens cap off). There's a threaded screw mount just inside of where the lens fits onto the camera. Take your filter and screw it into place. Hand tighten until it's snug and doesn't project in the way---remember, you're going to want to take it off again later.
Jan 15, 2011 | Rokinon 500mm f63 Mirror Lens for Nikon...
Dropped my canon t70 and the lens is all broken; can it be repaired if the body is still working fine?
The lens should be removable
See attached page
I am not familar with your exact camera, but I would suspect you have what is call a bayonet mount.
Look for a button around the lens in the body, push it, twist the lens.
I have acouple old lenses from my Alpa 9d (Dead) will they fit?
Mar 08, 2010 | Canon T70 35mm SLR Camera
Nikon D40 I bought a set of macro lenses that said they were compatible for the d40 but i cannot figure out how to fit them. They are 52mm lenses - should i have bought an adaptor or something? where...
Macro lenses are mounted to your camera body in place of the lens you currently have mounted on the camera. If you bought the camera with the lens already mounted you may not have realized that the camera and lens are 2 separate objects. To remove your lens see page 8 in your user manual for instructions and an illustration. If you don't have your user manual handy, you can download a PDF file from NikonUSA Here.
If what you bought are macro rings, they go on the camera, then your regular lens mounts onto the ring. You can use one or more of the rings between the lens and camera to produce different macro settings.
If what you bought are macro filters, they screw on to the front of your lens. If you have a UV filter on your lens you need to remove that before you attach another filter.
Dec 22, 2008 | Nikon Cameras
Quantaray is a private label lens made for Ritz Camera. They make this lens to fit several different camera brands including Nikon and Canon. The only ones that will fit a Canon camera body are the ones with the Canon EOS mount. If your Quantaray lens doesn't have an EOS mount, then it won't work on your Canon camera. You can take the lens to any Ritz Camera location and they can help determine which mount it has, and which cameras it will fit.
Jul 08, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Wide angle/fish eye lens
Hey matty reps,
I found one wide angle lens attachment that should work for your camera and I have attached a link to it so you can see what you think. I have little experience with these types of lens attachments, and have heard they're not nearly as good as having a wide angle/fisheye lens that mounts directly to the camera. If you don't mind losing autofocus you can usually find very cheap manual focus lens that are very high quality lenses for sale at some local camera shops. I hope this helps!
Go Ahead. Use Us.
May 29, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Yukon 100X (6-100x100) (6-100x100 mm) Logo
213 people viewed this question
Top Yukon Optics Experts
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
