I have an old a/c it was working correctly until i changed it's place to another house. It stats and runs normally for about 15 seconds then the electicity shuts down.
    Problem Solver:
  • 10 Answers
SEVERAL FACTOS.1.DOES THE NEW LOCATION HAS THE PROPER VOLTAGE REQUIRED TO RUN THE UNIT.POSSIBLE KICKING OUT DUE TO LOW VOLTAGE
Posted on Aug 08, 2010
How to change thermostat in 1995 dodge ram 2500
drain the rad into a pail.
remove the upper rad hose from the thermostat housing.
remove the thermostat housing
remove the gasket/seal (from housing or engine)
remove thermostat
install ne stat & gasket/seal
reinstall housing and hose.
close off rad bottom valve
refill rad with new coolant (with cap off run engine until warm
top up fluid to neck) replace cap.
dispose of old fluid at environmental recycle center
Feb 11, 2015 | 1995 Dodge Ram 2500
Change thermostat
HOw to change,? Out. R&R the STAT
no year, no engine option size stated.
so will do the generic answer, ive done this 3 times, now. here.
1: open hood.
2: see RAD (radiator)?
3: see top hose?, (called the return hose on most cars)
4: follow it to the thermostat housing, bingo, OFF the housing.
put back new SATat, (id run the hottest version for best MPG)
with the wax side to the water jackets.
and put jiggle bleed pin, up hill , (varies by engine design)
use the correct gasket for your engine size and year.
varies greatly.
use anti seize lube on the bolts. use torque rating in book, minus 15%
Dec 31, 2013 | Jeep Compass Cars & Trucks
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
No hot rads down stairs boiler comes on 3 miniutes then of again
Hello
By your post im guessing you have a 2 story house.
Have a look at the boiler,water pressure guage.Should be between 12 and 15 psi 140 to180.f when running.
If its above or close to 30 psi the relief valve will open to let off the pressure,we do not want this to happen normally.
If you have high water pressure at the boiler you will need to go to the highest radiator or any one on the second floor and open the bleeder.Looks like this
http://www.ourfixerupper.com/wp-content/uploads/2007/11/cast-iron-radiator-02.jpg
Carefully open it slow into a bucket,let air out until you get a steady stream of water.Do this to all of the radiators,idealy using a bleeder key or needle nose pliers.This may take some time.
Once we can assume all the air is out,check your water pressure again should be 15 to 20 psi.If you have no pressure then your auto fill valve is bad.If you have 15 to 20 then proceed.
Raise the temp of the t stat to start the boiler.6 degrees above whatever the room temp is.
If you still are having problems your t stat may be faulty.If your boiler is at 15 to 20 psi 140 to 180.f and it still shuts down after 3 min your return pump may be bad.
Hope this is helpfull
Dec 21, 2010 | Heating & Cooling
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
With new digital thermostat furnace runs every 10 min.
which type of T-Stat is it ? most standard t-stats have it built in that the temperature range is only a half a degree, it may seem like its running alot more, but in actuality it is maintaining better home comfort as it is not running as long as the old bimetal t-stats which would have a range of anywhere from 2-5 degrees which would cause the furnace to run alot longer, use more energy, use more fuel, and you would notice a definate change in the house temperture before it would come on or shut off, your t-stat seems to be working properly, and it will save you money, remeber also to change those filters !!!
Jan 20, 2009 | Honeywell Programmable Thermostat Heater
We recently bought a new house (to us). It has a Goodman heat pump and Goodman Electric backup furnace(A36-15) with a Janitrol stat. I switched the stat to emrg. Heat when the temp got below...
If you have a volt meter, check to see if you have 24 volts coming from the thermostat on the yellow wire.
If you do, and it is set on emer heat, you have a bad T-stat.
It looks like it is wired properly.
If you have no meter, you could try changing the stat, I reccomend Honeywell or white rodgers.
Let me know if you eliminate the Tstat as the problem and we can go from there.
Chances are its the stat.
Dec 06, 2008 | Heating & Cooling
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
