Question about McCulloch Garden
Cant get it started was going now wont - McCulloch Garden
    Brigadier General:
  • 4,088 Answers
Remove the spark plug and check for spark (gapped 0.020") which should be blue and snappy. If nothing, try a fresh plug. If still nothing, remove the cover to expose the flywheel and ignition module. Remove the stop switch wire from the module and try for spark again. If nothing again, replace the ignition module. Use a thin business card for a gap gauge between the flywheel magnets and the module poles. If the first test obtained good spark, pour a small amount of fuel mix into the plug hole and try for start. If it pops several times, then check the fuel filter, air cleaner, and muffler for plugging. Check the fuel line condition. Make sure the carburetor fasteners are tight. You may need to clean the carburetor inside and out with spray carburetor cleaner. Check the lower chamber diaphragm for flexibility and no holes or cracks. Hope some of this helps!
Posted on Aug 07, 2010
Citroen c8 wont start when its cold
probably your crank position sensor is bad. it determines the position of crank and adjust ignition timing. when timing is off it wont start.it cant catch. this is unrelated to outside temperature.
Nov 19, 2011 | Cars & Trucks
The kirby wont start no power
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Jun 20, 2010 | Kirby G6 Bagged Upright Vacuum
Pw 50 cc starts but wont stay started as soon as u go to
Are you aware the PW50 kill switch has a separate start and run position which will cause exactly that problem. it is a safety feature so the things cant be started with a full throttle and hurt the kids. If you already know about the switch sorry. but it still may be the problem if it is not contacting properly in the run position
Apr 16, 2010 | Yamaha G5 Motorcycles
1994 NISSAN PATHFINDER WONT START I LIKE TO FIND OUT HOW CANT I BY PASS THE MANUFACTURE SECURIETY SYSTEM . BUT I HAVE INSTALLED A AFTER MARKET ALARM AND I HAVE A BRAND NEW STARTER, ALTERNATOR , BATTERY...
First thing you should have done was check and test.NOT REPLACE PARTS.Did you test the battery to determine it needed to go? Had the starter failed to turn the engine over? The Alt supplies current to run the vehicle ,and keep the battery at the proper state of charge. How did you decide on ign wires verus the other ign components? Did it start and run okey ,before you added the after market alarm? If yes, I guess you know where some of the issues are!
Feb 18, 2010 | 1994 Nissan Pathfinder
2001 aztek turn on key lights come on wont start
sounds like the ignition lock cylinder has gone bad call a locksmith.
Feb 07, 2010 | 2001 Pontiac Aztek
Cant play youtube
Its because the Flash Player addons are probable disabled.
If your using firefox then go to tools - add ons - and find the flash player.
IE - go to Tools - Manage addons and thne select the ones called flash addon to enable.
Hope i helped.
Jul 05, 2009 | YouTube Videos
MY RCA LYRA MC5102A IS NOT WORKING RIGHT!
go to the thompson.com website and download the new software for your player..
Mar 26, 2009 | RCA Lyra RD2765 MP3 Player
I cant cut off my alarm and car wont start
is ti and aftermarket or factory system, if aftermarket look for little black button under dash or button on antenna, turn key on and press for one full second, if aftermarket unlock door with either trunk or passenger side and try again...
Jan 25, 2009 | Vehicle Parts & Accessories
Engien wont start!?!
You might need a new starter or a new alternator. Get it checked at a shop to make sure you find the right thing that you need to change.
Oct 23, 2008 | 1984 Ford Mustang
Garden Logo
71 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
