Question about Smeg Dishwashers
Acquastop failure. Code E1 The anti flooding sytem has been activated. The system is tripped in case of water leaks..
pagebor
  • 2785 Answers
SOURCE: Fault E1 appears in display
plz refer to diagram in the manual
Posted on Aug 07, 2008
SOURCE: Dishwasher Smeg DWD409SS
Hi
Please go to www.smeg-service.co.uk/support
Posted on Aug 21, 2008
SOURCE: anti flooding system
yes I will for $14.99 !
Posted on Aug 28, 2008
SOURCE: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Posted on Jan 10, 2010
tbirdfan1
  • 3051 Answers
SOURCE: E1 error code indicating anti flood has been
Hello there:
Yes this is a common error code on these machines the anti flood switch that is a sensor that sits at the bottom of the machine when water builds up on this switch this error code will illuminate
So what you need to do is disconnect any power to the machine
then if your has a panel at the bottom that can be removed remove it and look to see if there is a little tray in there if so it needs to be emptied this is normally done by tipping the machine towards you at a 45 deg angle then hold it there for 45 seconds this allows for the flood switch to be reset
Now take a towel and dry up any wires that are wet you may be able to see the sensor too where the tray is if so make sure this is totaly dry
then restore power to the machine and give it a try i have had to use a hair dryer sometimes also to help dry the wires under these machines ok that is just a hint though ok?
Hope this solution has helped you out Please feel free to rate this solution for me it helps get the best posiable solutions for customers ok?
Best regards Mike
Posted on Jan 17, 2011
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
My Miele washing machine has leaked everywhere, it said waterproof failure and now there is a tech fault code F224.
This leak should have filled the bottom tray and tripped the float level switch, this shutting down the machine. Once everything is dried up, you need to find out where the leakage is from. This really means removing the front door assembly in order to view the hoses and drain pump for instance. Without knowing the machine I cannot add more detail but you will need to investigate further. The leak should have switched off the electrical supply to the machine via the solenoid operated water inlet valve that is the anti-flood system. If this has not operated then it suggests that the water supply to the unit has caused the flood.
Feb 21, 2015 | Miele Washing Machines
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
There is no water going into the dishwasher even though the water supply is on.
Jan 24, 2010 | Miele 24 in. G665 Built-in Dishwasher
Hi my whirlpool dishwasher wont stop drainning even when the start button is of
Jan 24, 2010 | Whirlpool ADG450 Slim-Line Built-in...
It wont start and is flashing to the symbol of an arrow pointing to a line
Jan 24, 2010 | Dishwashers
Anti flood device has activated on my zanussi ZDF231,also there is quite aloud whirring sound ,like a motor struggling to work
The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water.
Jan 18, 2010 | Dishwashers
"E 1 code error
The fault is that the anti flood device is activating, you have a leak somewhere in the base of machine. Regards Engineer
Aug 05, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
167 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
