Question about Xerox Phaser 8560MFP Laser Printer
Hi I have an error code 09,035,43:3160 can you tell me how to fix it tried switching it on and off! but nothing its Xerox 8560
  • 4,323 Answers
Hi
This error mean that the there is an issue with the ink loader and/or ink sticks. 09 refers to the system having the issue (ink loader) and the 03x refers to the color having the problem ( where x=5 for cyan, 6 for magenta, 7 for yellow, and 8 for black). Your error code indicates that the issue is with the Cyan ink. Try removing the Cyan ink stick and then reinsert it. If this doesn't resolves the issue then try multiple number of times.
To clear the error, remove all the ink from the ink loader. Clean the ink loader system while the Xerox machine is turned off and unplugged. This may resolve the issue. However, if issue still persists then check if any of the ink left at the heaters is cracked. This is extremely difficult as it is hard to reach there. Perform a power cycle and check if error still exists.
If error still persists then try this reset procedure to clear the fault. Before the Xerox logo centers press and hold the back and help buttons. Once the machine displays beginning service mode release the buttons and it will reboot. Once it boots up in service mode scroll to the FUNCTION menu and enter. Now scroll to the CLEAR ISC FAULT and enter to reset. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 07, 2010
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Can anyone tell me what code 19,003.48 means for Xerox 8560?
19,003.48: Scale and offset error is too large. The voltages measured have more than a 20% error from their expected values. Something is wrong with the Electronics Module or the Wave Amplifier.
To prevent these discharges, a Grounding Clip (P/N 650442700) was added between the Y-Axis Motor mount and the Pick Clutch. Check that this clip is installed and contacts the metallic portion of the Pick Clutch.
Note
The Grounding Clip is factory installed in later versions of 8500/8550
models and in all 8560 models.
Oct 14, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
08,030.46:45203 error code with xerox 8560 printer
Are there obstructions or spilled ink on the Wiper Blade, the Head Tilt Gear drive path, or under the Printhead?
Is the Waste Tray overfilled?
Clean the inside of the printer and retest
Mar 10, 2014 | Xerox Office Equipment & Supplies
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
Printing stopped and got error code 09,038.46:79929 on Xerox Phaser 8560. can you help please?
Can you try this.
Switch off and switch on the printer
Hold the back and help buttons
Go to service mode.
Scroll down to the function menu
Scoll to clear isc fault
Hit the back button to get back to the first menu then exit diagnostics,
Hope this helps.. Good Luck
Siju.D
Nov 05, 2009 | Xerox Phaser 8560N Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Error Code 07,010.43:15005
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
Apr 01, 2009 | Xerox Phaser 8400DP Thermal Printer
Xerox Phaser 8560MFP Laser Printer Logo
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
