Question about Cabela's Oregon Scientific Indoor/Outdoor Thermometer with Alarm Clock
Searching for the cable which hooks to the wather vane II and which will run outdoors.. Thanks
  • Cabela's Master
  • 17,433 Answers
Do you have a model number?
Dont rate this answer yet.
Posted on Aug 10, 2010
I am trying to hook my Bose Acoustimass 15 Series II surround speakers using a Denon AV Surround Receiver AVR-1804/884 to my Sony DVD player and Panasonic LCD TV. I have the speakers all connected...
If the speakers work with test tones this has nothing to do with them and all to do with your attachment and setup of the sources.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1804-Receivers-manual/id/363bh837/t/2/
Stop guessing. Have you looked at all the manuals?
The other devices you're inquiring about are not named in your post. Name the makes and models first, then we'll look for the manuals. Then (maybe) find a solution. You could run them by the manufacturers' support sites or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
Google search: "(product) manual"
Apr 18, 2011 | Denon AVR-1804 Receiver
Corolla acceleration drops It runs for 5-10 minutes and then slowly acceleration start dropping and smoke starts coming from somewhere in engine (front left side). I am not sure if fuel pump is gone or...
I would suggest you to check the following
1) Carburetter (Flooding/Linkages/Overflow/Butterfly Vanes)
i) Air-Filter Assy. open and clean, check for leaks/holes
ii) Fuel Delivery System
iii) Fuel Tank for rust/sediments
iv) The grime on the carb can be from regular running and if the carb floods, then gummy petrol smelling deposit.
v) Also Check the Distributor Advance/******.
vi) If there is grime inside the carb, then the air-filter has a leak.
2) For the transfer-case
2A) Check if the oil on the T-Case is gear-oil (sulphur smell) or black/brown Engine Oil.
2B)If it is Engine Oil then you may have a problem with your
i) Crank Case
ii) PCV Valve - Postive Crankcase Ventilation Valve
iii) Main Bearing Seals, this is the worst case, indicated by the clutch becoming slippery i.e engine oil on the clutch pate & Assy.
2A ii) Check and clean the Breather Plugs. If the Plugs are blocked, then while running, the oil heats up and the hot air/gasses cannot escape, thereby creating a High Pressure inside the T-Case and vent through the oil-seals or weaker joints (sealing).
iii) After Cleaning the Breather if there is Gear Oil on the T-Case after running, service the T-Case.
May 08, 2010 | 1995 Toyota Corolla
The dishwater is not draining when the washer is running. What should be checked to help resolve this problem?
is wather filter dirty, or defective/stucked wather pump.
check the water filter, and listen if any strange noise on wather hose output. it requires a some handwork. is several metalic covers it needs to be opened.
post for extra indications
Jan 29, 2010 | Dishwashers
Engine runs away
there is a plastic vane that moves in response to the air flow created by the flywheel fan ... the faster the motor runs the more air and the more the vane is deflected .. the vane is connected to the throttle thru a spring .. as the vane is deflected it reduces the throttle setting to maintain a set speed (which is adjustable by a screw) ... if that vane becomes stuck by a leaf or twig then you lose that speed control .. also if it becomes disconnected from the throttle the engine will run away .. the manual on your generator will call that a "govener "
Dec 23, 2009 | Coleman Powermate Premium Plus 6250W...
I have an 18 K unit with E7 error on heat mode
I just installed a YMGI brand mini-split AC and had exactly the same problem. AC worked fine, but when I tried using heat mode I would get an E7 error.
After talking to their tech support I discovered the problem. There was a separate cable that needed to be connected that I'd forgotten to hook up. This cable runs from the internal unit to the outdoor unit and connects a defrost sensor.
In my case I had totally missed that cable when I installed the unit. After running another line and connecting it the unit is now functioning normally.
If this is a new install, then make sure all your cables have been run. If it was previously working, then check to see if one of the cables had become disconnected. If it's not the cable, then it's probably the sensor.
Good luck
Oct 18, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
How to get video/audio input from Xbox 360 & digital cable input
Hook them all to the tv and with audio out from the tv run that to the bose 321.
Mar 14, 2009 | Bose 3·2·1 II System
Top Cabela's Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cabela's Audio Player and Recorder Expert? Answer questions, earn points and help others
