Question about Panasonic Office Equipment & Supplies
How to install panasonic fan f-mx405 - Panasonic Office Equipment & Supplies
I do not see how to get at the lightbulb in my Panasonic Whisper Fan/light. I can not see any way to open the cover where the light is. What is the procedure?
Hi, I searched the web for answer and finally got it from the installation manuel. You have to take the whole cover off, not just the cover for the light. Below is the website for the installation manuel. ftp://ftp.panasonic.com/pub/Panasonic/business/building-products/ventilation-systems/pdf/install/08VFL2-E.pdf
The answer is on P.13-14.
Aug 15, 2011 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
My Panasonic FV-11VQL2 seems to have the damper stuck in the closed position. The fan does not exhaust well, ever since we got a new roof (vent and 4" duct too). Any way to unstuck it without going into...
Hubby went into attic. The roofer did a poor job installing the new 4" duct and roof vent; duct was poorly attached and pinched at both ends. He redid both connections, and now the fan works well----no more foggy, drippy mirrors!
So, the fan is fine------the installation of the new roof vent and duct was shoddy.
Aug 24, 2009 | Panasonic Dryers
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
I had a Panasonic bath fan installed the week before Thanksgiving. It was represented that this fan was virtually silent. It is however, noisier than the 22-year old fan it replaced. My contractor tells...
Vibration noise is usually due to inballanced, or damaged fan blade.
Take off the coveer, make sure its installed properly, the blade is not cracked, and check for ballanced motor/bracket/blade.
They typically have rubber bushings between the motor mounts and the housing to dampen vibration noise.
Dec 17, 2008 | Heating & Cooling
Odors backing up
Those fans are only designed to remove steam and high humidity from bathrooms to prevent mold.
Aug 11, 2017 | Panasonic FV-05VQ3 WhisperCeiling Fan
Odors are backing into the bathroom after installing the whiperfit
try to install the fan at a lower height so that it can drive out all the smoke. This is because the fan can driveout air with in a certain radius and installing it at a lower height increases it..
Jun 16, 2008 | Panasonic FV-05VQ3 WhisperCeiling Fan
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Feb 25, 2008 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
70 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
