Just bought a verine eden gas fire and i cant get it to start, batteries in the remote are new so the problem has to be something else. the pilot light not coming on.
2 Suggested Answers
SOURCE: paragon 2000r gas fire -
I have the same problem occasionally with a Paragon 2000R. It seems to be related to the thermocouple. The pilot flame does not heat the thermocouple enough. Usually re-arranging the the artificial coal to reflect some of the heat back to the thermocouple will just make the difference. Maybe it is time for a new thermocouple.
RB
Posted on Sep 27, 2011
I NEED MANAL FOR GAS LOGS #LDL3924PRA OR LDL3924PR
I have the LDL3924 Propane model with Nova Remote system.
My pilot back fired recently and wouldn't work. I turned off the gas, Bought a can of air , Used air to Clean Pilot Didn't work. So I just replaced Desa part 103778-01 also listed as pp225. Do a search for Desa 103778-01 and see a picture. Bought mine from S.A.W. Inc. on ebay about $80.
Jan 29, 2013 | Heating & Cooling
How to light a pilot on an electric ignition heater i have followed all the directions on the heater and it still won't light
most elecrronic ignition gas heaters are remote control so you should have a remote or a wall switch some where and this means you shouldn't really have to touch any of controls inside heater and the manual starting of these fires is for service technician i suggest making sure that gas supply line you have to heater, check stop valve is on to let gas through. You then need to make sure the heater's isolater switch is on if has one so it gets 240v for electronic ignitor unless it is battery powered which obviously you need to change batteries in and if all fails from there i would call service technician, unless you are one yourself as above stated is all you should do if you are not a tech. Also your pilot may be faulty or may have had an eight legged intrusion into pilot stem itself it does happen have found spiders in pilots but its usually the web that causes problem so you should definatly call service agent.
Nov 18, 2010 | Heating & Cooling
Robinson wiley gas fire operation instructions
not sure without seeing the unit , but if you are following proper lighting instructions and the pilot wont stay lit either the saftey valve isnt working or you dont have enough gas pressure if the unit has a themocouple then you may be able to replace the thermocouple. let me know
Dec 17, 2009 | Kitchen Ranges
I just bought a Lennar home in the Hanford area. It was a foreclosure. There is a Heat n Glo doublesided fireplace. No manual for operation. How do I get the thing started? There is a red gas valve on the...
i would really suggest having a gas log service company come out . 2 reasons 1st it should be maintenanced every year and 2 its a gas appliance have a qualified person explain the operation visually
Nov 28, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
FIRE GOES OUT AFTER AWHILE
Hi clean pilot light check out thermocouple might need new one
Nov 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
