Question about Carrier YCB213D Air Conditioner
My Carrier 21000 BTU air conditioner (model YCB213E built in 1996) has always worked perfectly until yesterday. When I pushed the red button to turn it on - nothing happened. The digital screen shows the letters PF but not the words that usually appear. Since I cannot find the owners manual, I am currently clueless. I would like to be able to fix it myself if possible since it weighs a ton and would be a real pain to remove and take to a repair shop. Any advice at all on where to start would be greatly appreciated! Thanks - Jim
Carrier 60000 btu/h air conditioner model number 42SD7C what type of refrigerant gas uses?
Should be on a label inside
Carrier use the newer R410A gas. You need a refrigeration engineer to work with it anyway and they will know.
Does your air conditioner use R-22 refrigerant? Here's why you should ...
www.startribune.com/does-your-air-conditioner-use-r...refrigerant.../428178123/Jun 13, 2017 - Most air conditioners use one of two types of refrigerant; R-22 or R-410A. The price of R-22 is starting to skyrocket, and prices won't be coming ...
Installation manual
https://www.carrier.nl/~/media/Product_pdfs/.../RAV-SM1603AT-E_NL-UK.ashxThis Air Conditioner is a new type which adopts a new refrigerant HFC (R410A) ... Take out the flare nut attached to the air conditioner, and use it. ... Guard material for passage part. 1. For protecting passage part (pipe cover) ... If refrigerant gas has leaked during the installation work, ventilate the room ..... Number of bent.
May 25, 2018 | Carrier Heating & Cooling
Air conditioner 253-70251
drawing to many amps. can be capacitor issues.
May 11, 2014 | Kenmore Model 253.70181 Window Air...
Want to know how many btu lca061p
6050BTU
Carrier LCA061P 6050 BTU Thru-Wall/Window Air Conditioner
Jul 11, 2012 | Carrier LCA061P Air Conditioner
How many tonnes does this air conditioner have?
First digit after 38CKC_0_ is the seer rating this is a 10 Seer unit.the next two digits are BTU's of cooling to the thousands. For every 12,000 BTU's you have 1 ton of air conditioning.38CKCO_36_ would be a 3 ton unit.
Serial number first two digits are the week the second two are the year24 would be 24th week. 02 would be 2002
Jul 08, 2012 | Carrier 38CKC036 Air Conditioner
What is the tonnage of a carrier model #240ABB360A320
LOOK ON ID TAG SHOULD HAVE BTU # 12,000 BTU EQUALS 1 TON
Apr 03, 2012 | Carrier 38CKC042 Air Conditioner
What size BTU unit is my Crarrier model 38ck036330 condensing coil ?
The model you gave is for a 3 ton or 36000 BTU unit...that is what the 36 stands for in the model number...
heatman101
Aug 24, 2010 | Carrier Heating & Cooling
Need btu rating ???
Carrier YCB213D Y Series Window Air Conditioner 21000 BTU 230/208V. No Remote Control. High-efficiency energy-saving units. Quiet cooling for living areas.
Please dont forget to rate ;o)
Aug 17, 2009 | Carrier YCB213D Air Conditioner
Have a carrier zonemaster air conditioner and no operating instructions can you help
At the risk of seeming smart, try a few knobs buttons or pad pushes. I suspect it has enough safety built in the avoid an unsafe or damage the unit. But see if you try these things maybe you can tell us what it doesn't do.
Dec 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Product # 38BRC042320
This unit was manufactured 1/8/00 and is a 4 1/2 system
Sep 30, 2008 | Carrier 38CKC036 Air Conditioner
Carrier YCB213D Air Conditioner Logo
325 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
