Question about Neff 24 in. S5443X2 Built-in Dishwasher
Neff S5453X1GB/55 The problem is the flotation chamber at the bottom keeps filling with water which cuts out the water filling, where would the leak be.
5 Suggested Answers
  • 1314 Answers
SOURCE: Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Posted on Feb 18, 2008
  • 190 Answers
SOURCE: water leaks into bottom tray when filling
dear batties,
Such water filling problems can be generally solved by checking the following
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Also for the mid cycle problems check the following
hope u find this useful. thank you for using fixya.have a great day.
Posted on Jul 09, 2008
SOURCE: Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Posted on Aug 26, 2009
SOURCE: Require wiring diagram for Neff
The control unit get damage for diswasher door type, I need new one for replacement.
thanks
Emmanuel Ugoh,
UBAGU GLOBAL VENTURES LTD
Posted on Jan 27, 2011
How do I remove a Neff S5453X1gb/46? All wiring and plumbing disconnected, front legs released but can't move dishwasher out, help!
Unlikely you have been puzzling with this since 10/20 and have probably found the side mounting screws (with plastic caps) on each side at the front of the frame.
Oct 20, 2016 | Neff Dishwashers
Flotation devise does not cut of water supply
Adjusdt the float level, still same problwm replace fill valve assembly.
Dec 30, 2013 | American Standard Flowise 2480.216.020...
Neff s5443x1GB/29 dishwasher starts and stops
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 16, 2013 | Neff Dishwashers
Neff dishwasher constantly pumping
Possibility is the pressure chamber or hose (pressure chamber to sump) is blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 04, 2013 | Neff Dishwashers
Water not heating up
Could be a heater or pcb failure, if you are hearing the bang/knock during fill up it could be the water is not reaching level and then the heater will not come on (boil dry sensing) try the following. Turn mains off first.
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning). If the pressure chamber is excessively blocked it will probably need replacing. Costs approx 25pound direct from Bosch service division (BSH Home Appliance Ltd).
Best of luck
Mar 16, 2013 | Neff 24 in. S5443X2 Built-in Dishwasher
Not filling with enough water
If you remove the lid and looking at the front of the d/w take of the lefft side panel, at the right bottom on the side you should see a pressure chamber with some micro switches and a red lever. This is possible blocked along with the hose that is attached to it (to the right, behind the chamber) clear them both and retest with the side panel off to check for good flow and to make sure you have not created a leak.
Good luck
Jul 08, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher s5433xogb/29 pump keeps running
Our Neff Dishwasher S5456X0 the pump was running all the time and the solution 1 worked. We removed the front panel under the door and the the flood camber was full of water. Drained it out with a sponge and the dishwasher is fine. Thanks
Nov 20, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Water fill does not shut off
problem caan be the pressure switch. to test it, put on a length of hose, set machine going and use your mouth to pressurize the hose and water should stop. if it doesn't then pressure switch is faulty.
also the pressure switch hose goes to an air chamber and this can be clogged with gunge
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Water leaks into bottom tray when filling
dear batties,
  • Check the pump
Jul 09, 2008 | Neff Dishwashers
Neff 24 in. S5443X2 Built-in Dishwasher Logo
76 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
