Question about GE Spectra JBP78 Electric Kitchen Range
I cleaned my oven last night and now when I turn it on, the clean light simply blinks and I cannot use it
  • GE Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Aug 08, 2010
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
I have a modern maid double wall oven (gas). I set it to clean last night (at 3:00AM). It is now 12:PM the next day and it can't unlock it. What should I do?
Try turning the main power off to the house for 5 mins and turn it back on see if that reset your oven.
Jan 01, 2015 | Ovens
Oven Door Locked After Cleaning
Go to electric panel. Turn off the oven breaker, open door, now turn breaker back on.
Jan 16, 2009 | Ovens
Blinking auto self clean light
There is probably a switch attached to the oven locking mechanism that need to be replaced. I had a similar problem on my GE electric oven and it worked for me.
Nov 16, 2008 | Kitchen Ranges
Oven lock light
Oven lock is usually associated with oven cleaning. Last owner probably tried to clean the oven for you and didn't finish the cycle. Either finish cycle or turn it off (if possible).
Oct 03, 2017 | Maytag MEW5530D Electric Single Oven
Need help unlock oven after self cleaning jenn air jjw9527
The temperature setting must be set on "Cleaning" and the oven cooking dial to "Clean"; otherwise the door will not open and forcing will damage the mechanism. Also, before the door will open, the internal temperature must drop to a safe level and a red "cleaning" light must go off, after the temperature drops inside the oven.
Aug 23, 2008 | Jenn-Air Ovens
I can't stop cleaning!!!
I had the same problem. The issue is in the electric switch that tells the oven whether the door lock is latched. If the switch gets stuck in the "clean" position, even though the lock is released, the oven will not run the regular cycles. If you wiggle the lock levr a few times it may free the switch, otherwise you'll have to raise the cooktop, and there is a metal cover over the mechanism. Remove the 2 screws holding the switch (unplug the power first) and you should be able to un-stick it. Reassemble and you're good to go, at least until you need to run the cleaning cycle again...
Feb 26, 2008 | Hotpoint RGB745 Gas Kitchen Range
Self clean light blinks, oven does not work
You were right. The locking mechanism switch somehow became jammed and the oven thought the door was locked, even though I could open the door. I didn't know if I was supposed to take the top off and moving the lever back and forth did not help. Finally I turned the oven on and just kind of jiggled the latch in the unlocked position. I kind of moved it back and forth furiously and the cleaning light stopped blinking and the oven light came on. I'm glad it is working now, but I will be manually cleaning my oven from now on! Thanks for your help.
Dec 25, 2006 | GE JGBP26 Gas Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
102 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
