Question about Exercise & Fitness
Runs for 5seconds and error1 - Exercise & Fitness
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 11, 2010
Machine error1 broke needle then machine come error1 can i override
Look for Error 1 in the troubleshooting section of your owner's manual or search for:
Make Model Error 1
May 26, 2018 | Sewing Machines
Hydrovane 845 running for only 5seconds and then stops
your heat sink my not be fast to keep it cool
Oct 25, 2013 | Computers & Internet
Runs 5seconds then cuts off
Please post a new question, and please include your brand name and the full model number from the tag in or on the unit as well as detailed symptoms so we can help you.
Oct 08, 2009 | Panasonic Microwave Ovens
Mazda runs for 5sec then stops
check your fuel pressure regulater..it is located on the left back side of the intake manifold close to the fule rail..
Dec 02, 2008 | 1998 Mazda 626
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
82 911sc
Check your spark plugs, fuel filter and fuel pump. Basically car needs spark and fuel to remain going. Check all those and replace when necessary.
Jun 16, 2008 | 1982 Porsche 911
Exercise & Fitness Logo
275 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
