Question about HP Pavilion dv9000z Notebook
My computer will not turn on. There are blue lights that come on, but than goes off and nothing comes up on the screen. Can you tell me what's wrong
  • 225 Answers
The motherboard is faulty. It is very frequent problem with the entire HP The motherboard have to be replaced. You may find the correct part number under the RAM when you open its cover on the bottom.Order it from ebay. It is probably the chipset IC get lost contact with the board but it is hard to resolder and the success is rare.
You will have to take apart the entire laptop to replace the motherboard. Start with the battery, covers, HDD, panel with the power button, keyboard. Then remove the screen lid from the base. (Do not take apart the lid, just detach it)
Then remove all screws on the back and take out the upper cover with the touch pad. Remove the DVD, the fan, the heatsink and the processor. What will left is the case with the board. Remove the screws and take it out. Assemble with the new motherboard in the reverse order.
Posted on Aug 07, 2010
Did you ever solve this problem I am having a similar issue with a Presario F756NR and just wondered if you have an update.
Posted on Aug 31, 2010
    President:
  • 2,291 Answers
Put out ur battery for some time and then put it again and then try
Posted on Aug 26, 2010
    Problem Solver:
  • 9 Answers
This is usually due to a problem of hardware components in your motherboard, may be some have to be replaced. Its would be better to consult a techician.
Posted on Aug 25, 2010
    Problem Solver:
  • 11 Answers
Maybe something are wrong with your database system
Aoc monitor won't turn on
the power supply has a capacitor which has either opened up or shorted across. If you open it up and look at the caps (round cylindar looking things), you might see some that look like they have "balooned". If the top of them is not flat and the cylindar is warped at all, that part needs to be replaced..
These are what always goes wrong with monitors, so give it a whirl and you will probebly save yours..
Jan 30, 2014 | AOC Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
I have the presario V6133CL with the not starting problem ( blue lights, goes off, back on blue lights) press and hold power button computer stops. Press power button and computer comes on and works like...
Do a search for Easeus data recovery wizard. Install and follow instructions.
BTW sounds like you will have problems again. Your graphics chip may be on its way out.
Apr 05, 2011 | HP Compaq Presario V6133CL Notebook
Hi i have a hitachi tv, serial no:v71100318. the tv hasnt worked properly for the last few weeks, i switch it on the standby light is green blue screen comes on then the screen goes off and standby light...
sorry but the serial number doesn't tell anything about a set, the model is what you need first, it could be lamp but don't know the model
Feb 13, 2011 | Hitachi TVs
Presario C700 won't turn on after installing new screen
Why was machine taken apart? Did you check memory to make sure it's sitting correctly?
Jan 06, 2010 | HP Compaq Presario C700T
Our compaq monitor will not go on. It is plugged in and the green light goes on when the button is pushed, but nothing comes up on the screen after moving the mouse. Our Presario computer is turned on. Any...
Make sure it is properly plugged into your computer too. (blue headed cord) should go from the screen to the computer. Make sure the cord is not damaged.
There should be a total of two cords needed (one for power (black) and (one from the computer to screen (usually blue))
Oct 18, 2009 | Compaq 15 COLOR MONITOR***
TV Not turning on , but blue power light is on
look in the back, see if the lamp is actually lit. If it is probably not a tv problem. If you can pull up the menu then you probably are on the wrong input. Are the fans running when you turn it on? IF fans are running might be lamp, if nothing is seen through the back.
Apr 29, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
The crazy blue box
crazy stuff here.. it might be the display or the harddrive check the pins on the display cable. how old is the PC? and have you added anything to the computer to damage the motherboard? I suggest doing a system recovery it might solve the promblem.
Sep 12, 2006 | E-Machines eMachines Refurbished EMA...
HP Pavilion dv9000z Notebook Logo
401 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
