Question about NetGear ReadyNAS NV+ RND4475 - NAS - 3 TB - Serial ATA-150 - HD 750 GB x 4 - RAID 0, 1, 5 - Gigabit ... (44229G)
The paths for the shares listed below could not be found. Typically, this occurs when the NAS is unable to access the data volume. media
DLNA protocol error 7531
This is caused by the NAS hybernating
you can either tell the ps3 not to let it hybernate (i forgot where that setting is) or you can disable then re-enable the media serve, which is under the System Settings - Network Settings
Dec 05, 2012 | Video Game Consoles & Games
Tip
Stream AVCHD videos to Xbox 360 via DLNA-AVCHD to Xbox Converter
Xbox DLNA-AVCHD MTS/M2TS to Xbox 360 support formats on Windows 7 <br /><br />Generally, I have my video to be kept in a D-Link NAS box, so that I can watch them on Xbox. The NAS is quite old, and I will buy a home server similar to the HP models one day. Xbox has a "Windows Media Center" window in the dashboard view, and <b><a href="http://dts-ac3-converter.com/2011/07/stream-avchd-videos-to-xbox-360-via-dlna-avchd-to-xbox-converter/">Xbox Streams videos from NAS via DLNA for HDTV</a></b>. <br /><br />However, the AVCHD files from my Sony DSC-TX100V could not read by Xbox. While looking for the solution to <b><a href="http://www.aunsoft.com/final-mate/">stream AVCHD videos to Xbox</a></b>, I find Aunsoft Final Mate as the recommended AVCHD video converter and joiner with best quality. After dealing the AVCHD files with Final Mate on Windows 7 Premium, I can share the videos using Windows Media Center software for streaming. <br /><br />Below is just a simple guide with AVCHD to Xbox supported format. <br /><br /><b>Step 1. Import AVCHD videos to Final Mate.</b> <br />Run Final Mate as the <b><a href="http://www.aunsoft.com/final-mate/">best AVCHD to Xbox converter</a></b>, and click the Add file path button on Resource tab to browse the folder with .mts or .m2ts files on PC hard drive. For videos from camera, just connect camera to PC via USB cable, and follow the pop-up wizard to import videos. <br /><br /><b>Step 2. Select and join AVCHD files for output.</b> <br />Select the clips on Resource tab or Camcorder tab, drag and drop to the Movies tab. You can create a movie for each file or a movie with several files with conversion. For another movie, just click the Create New Movie button. <br /> <br /><b>Step 3. Choose Xbox format.</b> <br />Click the icon next to the Movie name in the Movies tab, you will see the format options. Move to the Device group, find Zune/Xbox 360 Device and choose Zune Xbox 360 - Windows Media Video(*.wmv) as output format. <br /><br />Click Export button, and the conversion from <b><a href="http://www.aunsoft.com/final-mate/">AVCHD to Xbox 360 support format</a></b> will start right away. Wait for a while, and put the videos to the video folder for sharing. Xbox 360 then can stream videos from the NAS via DLNA.
on Jul 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Access to the NAS-T2 from Linux
Quick tip: when accessing the NAS-T2 from Linux, mount any NAS-T2 shares using smbfs, not cifs.
More detail: This tip presumes you're familiar with mounting filesystems in Linux and are trying to mount an NAS-T2 share in Linux. The older smbfs filesystem type for mounting Windows shares is deprecated in favor of the newer cifs filesystem type. However, the NAS-T2 is built on some older flavor of Windows and behaves very oddly when mounted as a cifs filesystem. Changing back to the older smbfs filesystem type solved all my problems.
on Jan 13, 2008 | Fastora 2 Bays Network Attach Storage...
What is nas
network attached storage server using bsd.used for backup
www.nas.org
Feb 05, 2011 | Microsoft Windows XP Professional for PC
I am using server 2003 as file server wchich is in workgroup and connected to the network. problem is arising when any system from the network wants to access the shared folder the user unable to access...
Try this:
go to start>run and type: \\ server ip address
for example, if its 192.168.10.20, type \\192.168.10.20
Navigate to that shared folder, right click on it and create shortcut.
If the previous step doesnt work, go to server, unshare that folder, restart and share it again. Try accessing it.
Hope this helps
Aug 11, 2010 | Microsoft Computers & Internet
Cannot detect the lacie 1tb exreme big disk
Hi there!
Same issue here
Running win XP on my laptop and I have my LaCie NAS on my network and was working fine 'til today.
Issue: unable to access my LaCie NAS
troubleshooting done:1- rebooting NAS 2-power cycling the whole network 3- also tried accessing NAS from a Mac Book (used to be able) 4- nable to ping it by name or by IP
I had one my NAS's shares mapped to Y:, Now I can see the share from my network places but when I go to map network drive the Y: is no more assigned to that share.
My next move would be to re-install the NAS but I want to know and make sure that this will not delete what I have on that NAS.
Thanks to anyone that would jump in and give a hand to a desperate novice in Networking
Sep 30, 2009 | LaCie Big Disk Extreme (300797U) 1000 GB...
Share/files deleted from my simple share nas device.
You may use data recovery software to see if you can rescue the files. It may unable to recover all the files, but at least most of them.
Feb 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Cant able to access the 1tb network storage
Consider a few things that may solve the problem:
1. this is how I always like to test; shut down the NAS drive for a minute and reboot; once rebooted see if it is accessible
2. need to know the ip address of the NAS drive and make sure that ip is not blocked by your system firewall (e.g. add that ip into trusted address on the firewall program; or temporarily disable any anti-virus or firewall and see if you can access, and if you can then it is the issue of firewall),
3.unless you have customized the settings, open my computer and on the addressbar type type the ip address if you know (if it is WD Mybook World then you can also try typing \\mybookworld on the address bar); in this case also try it by temporarily disabling any anti-virus or firewall program
4. one way you can figure out the ip for your nas drive is through the router's homepage; since I don't know your router type I can't give you specific steps; but try to get onto the router's main page and see the client's list or DHCP Client's List or something similar where you should see an ip also assigned to the NAS drive which is connected to the same router.
Post the feedback what happens... we'll see... good luck !!!
Jan 09, 2009 | Western Digital My Book World Edition 1TB...
Problems installing ms office pro 2007
hi Error 1706 is a Microsoft error that is sometimes generated when you install a Windows package from some form of removable data. Examples of removable data would be a CD-ROM or a DVD. Typically, the exact text of Error 1706 will include the phrase "no valid source could be found."
One of the usual causes of this problem is that the Windows Installer or MSI file is not residing in the root folder of the media that is found on the removable data. This does not mean that the MSI file is not somewhere on the media -- just that it is not in the folder that your system is checking. While, in most cases, the Media Package Path would be altered to create a clear path to the MSI file.
thank you
Oct 05, 2008 | Microsoft Office Professional 2007 Full...
Can't Access Public Shares via NFS
You can mount the shares something like this:
mount -t cifs -o username=backup,password=YoUrPaSS //192.168.0.145/projects /mnt/nas/projects/
...where 192.168.0.145 is IP of SS4000-E and /projects is the shares folder
and /mnt/nas/projects/ is folder you have created on your Linux box
Hope this helps
Best Regards
ashley
Apr 11, 2008 | Intel SS4000-E (SS4000ENA)
Open Questions:
netgear readynas nv+ 4210 problem to create and config share I have a readynas nv+ 4210 (2T) (securyty mode user) I have four shares: media, backup, utenti, prova. When I try to create a new shares it gives me this error: The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. ditutti pubblica [Fri Oct 16 10:22:22 CEST 2009] I thought that the name pubblica, I try to use as name of the share, is reserved but now I can't stop this message and I can't creare a new share. So I used ad addon suggest by netgear. I obtain to review all the shares I had cancelled but if I try to delete one of this share nothing happends. I delete the share and when I reboot the storage nothing change. The wroste thing that happends is that I cannot configure the share I see. If I try to configure the nfs and the Share Access Restrictions they doesn't take effect. the client, trying mount a share with default access Read/write, receive this error: access denied by server while mounting ... With showmount -e ip number I obtain : /ditutti * ditutti is a share that I have and try to delete. If I mount another share like backup I'll never delete, everythig goes right. i mount it without problems. With the showmount command it seems: /c/backup [ip], [ip] (ip because I decided to restrict the access) If I try to create a new share, it doesn't give me any errors but the new share is not listed with the other So I decide to restore the storage with Factory defaults. I create the volume and the user I need and the share. When I config the nfs, ftp protocols for all the created share. When I try to config the ftp protocol for the share utenti i had this error: Unsuccessful mounting ftp share utenti Note I made the same things with the other two share were I had no problems. After that the share utenti is not possible to mount. With the showmount command I see: /c/pubblica [ip], [ip] /c/servizio [ip], [ip] utenti [ip], [ip] Utenti isn't in the /c/ the only difference I had. Before to proceed with the configuration of ftp and had the error i can mount utenti without problem but now ... if I try to delete it the share remain like I do nothing. I can mount the other share without problem but not the utenti's share. When I try to delete the share I can't do it also if I use the add-on of netgear. What can I do without formating or using the factory defaults? Now I have no data in the storage now but for the future I'm very interesting to solve this question.
Nov 23, 2009 | NetGear ReadyNAS NV+ RND4475 - NAS - 3 TB...
NetGear ReadyNAS NV+ RND4475 - NAS - 3 TB - Serial ATA-150 - HD 750 GB x 4 - RAID 0, 1, 5 - Gigabit ... (44229G) Logo
864 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
