Computers & Internet Logo
Posted on Aug 07, 2010
Why isnt my belkin play max router working at all?
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Aug 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
4981
Points
89
Do you get power to it? If you do connect to it using a network cable (ip address or connection address will be in the manual) and setup the router make a note of security settings and type of connection. Connect a wireless device (if not intergrated) to your pc or laptop, load the drivers and setup according to router settings.
If router doesn't connect to the internet contact your ISP for details.
tip
To get rid of multiple issues with belkin routers
To resolve the issue with Belkin routers:The routers that are released recently by Belkin Inc., are Basic / Connect N150, Surf / Surf N300, Share / Share N300, Share Max / Share N Max300, Play / Play N600, Play Max / Play N600 HD
  • These routers comes with a software CD.
  • Belkin router monitor is the software that gets installed in the computer when you run the setup CD in your computer.
  • This software is really an unwanted one that takes around 30 minutes to get installed in your computer.
  • In addition to that, this software displays unwanted popup messages.
  • 90% users are not aware that they can use the routers without installing any software in their computers.
Inorder to make your router properly, these steps has to be followed...
  • The belkin router monitor software has to be uninstalled from your computer.
  • Firmware of the router has to be updated to the latest version available from the belkin support site.
  • Self healing feature of the router has to be disabled.
  • Wifi protected setup (WPS) has to be disabled.
To uninstall the belkin software:
  • For Xp computers, Goto control panel > Add or remove programs > select belkin setup and router monitor and remove it.
  • For vista & win7, Goto control panel > Uninstall a program > select belkin setup and router monitor and remove it.
To update the firmware for your router:Goto http://www.belkin.com/support/
  • Select your router and download the firmware for your router. The file with a .bin extension will be downloaded to your computer.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router http://192.168.2.1
  • Belkin router setup utility will be displayed.
  • Login to the page. (password: leave it blank and click submit)
You will have the status screen.
In the status screen, you will have the very first box in the centre of the screen says "version info", under that you will have firmware version.
Just note down the firmware version there. If the firmware version in router is lesser than the one downloaded from support site, then the firmware has to be updated.
On the far left side below the Utilities you will have "firmware update", you need to click that.
Now on the right hand side you will have "browse".
Click on browse and locate the downloaded .bin file from your computer and click update.
Click ok for all the warnings.
You may see a count down now.
Once its done you will be brought back to the status screen.
Login to the router again with a blank password and click on restore factory defaults below the utilities and click ok for all the warnings.
Now the firmware of your router must have updated with the latest version.
To disable Selfheal:
On the far left side below the Utilities you will have "self heal", you need to click that.disable the self heal and apply changes.
To disable WPS:On the far left side below the Wireless you will have "wifi protected setup", you need to click that.wifi protected setup will be enabled by default, disable it and apply changes.
Click here to learn more about wps...
tip
How to solve the problems with Belkin's Next generation routers ?
Please keep a book mark of this page... datas are being collected for belkin's next generation routers....
Model numbers of routers are
Basic F7D1301 v1
Surf F7D2301 v1
Share F7D3302 v1
Play F7D4302 v1
Play Max F7D4301 v1
The same will be updated soon...
on Jul 22, 2010 • Computers & Internet
How do we Reset our Belkin Play Max Router?
If unplugging, and hitting the reset switch does not work, then odds are the problem isn't with your router, but with your service provider.
Remember, internet provideros, whether they are national companies, or a local networks, have equipment that needs replacing, and or upgradews.
The problems that most service providers have is with switches.These switches wear out and need replacing.
Sometimes resetting the router allows the modem to reset to another address by connecting to another address, however, sometimes when they are replacing hardware, usually high end tech resetting won't work, until they have finished replacing the equipment.
Uninstall firmware on Belkin
Not a Firmware uninstall but update a latest firmware Download And Update.
Recently bought the Belkin Play max router F7D4302 & wireless play adapter F7D4301. I'm having intermitten wireless disconnection. Everytime when the wireless adapter disconnect after every...
You may need to update your adapter drivers> Here is a site for Belkin and your adapter:
http://en-us-support.belkin.com/app/answers/detail/a_id/3748/~/f7d4101-play-wireless-usb-adapter---drivers-%26-software
I can establish a link to the Net wirelessly and on the LAN, but for some reason I cannot get the USB aspect working. The green light is on for the net connection and also for the USB, but the Belkin USB...
Hi you need to be sure is the default settings of your router Belkin is USB ENABLE .
  1. for that go to setup page Belkin .
  2. open a browser explore and erase the address bar
  3. type 192.168.2.1 and setup page will be open
  4. be sure USB is Enable is not just change the status of Disable for Enable
let me know is that still not working and ask me for a remote your PC
The wifi connection to this belkin play max is not stable, sometimes get connected, sometimes not. i connected the external hard drive to the usb port, at first i can see the drive using belkin router...
OK let me disable something in your router
QOS
Supported Products - Play Wireless Router (F7D4302), Play Max Wireless Router (F7D4301)
Using QoS rules on your Belkin Router helps provide both bandwidth and priority to network traffic so it can pass without its performance being affected. It allows users to classify traffic of applications and provides them with differentiated services (Diffserv).
Setup Steps
  1. Click on the green Belkin Router Manager icon (right-click for Windows) to open the menu.
  2. On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
  3. Click to open the Belkin Router Setup page on your Web browser.
You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
  1. From the QoS Profiles page, you can easily set up QoS rules.
  2. Click the "Apply Changes" button to save your settings.
Also disable WPS and Firewall in router.
let me know .
please don't forget to rate techbelkin
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
