Question about Oase BioTec 10.1 Filter
How do you maintain the oase biotec 10 as I do not have a manual
When I switch my oase pond vac on it switches off immediatly
Sounds like a ground fault or polarity issue with the connection. Check your wiring with the circuit breaker 'Off" and verify it's "off" using an electrician's screwdriver. This will also tell you when you put the power "on" whether the polarity is correct.. red is positive, black is negative, and as always, Green wire is ground.
Apr 24, 2015 | Oase Garden
Oase helpline
www.lowes.com/cd_Remove+Algae+from+Your+Pool_13040116..
Jul 06, 2014 | Garden
Oase sp310g
Yes.Get the new impeller,take the unit apart,remove the impeller and put the new one on.Just do it.You never know tilya find out.Only way to find out is to just DO IT.
Apr 15, 2014 | Garden
Hi got oase filter and everything just stopped working including the pump please could you give me some advice on what it could be thank you
It could be no power, bad wires, bad controller, bad switch, bad pump. You may have something as simple as a tripped Ground Fault Circuit Interupter (GFCI) breaker or receptacle. That is what I would check first. If you reset it and it trips as soon as you turn on the pump switch then you have a ground fault in the pump. I hope this helps.
Aug 30, 2011 | Oase BioTec 10.1 Filter
MY OASE PUMP SEEMS TO BE LOW ON POWER, IT PUMPS WATER BUT NOT ENOUGH TO GET TO THE FILTRATION TANK
Check to be sure that the impeller is not clogged in the center of the fins.
Sep 09, 2009 | Garden
My pump keeps triping the electrics off
if this is a new installation you may have too much load on one circuit, if it is an old installation check to see if something else has been added to the old circuit.ie: microwave lights applaince etc, if this isnt the case you have a short somewhere in the water pump and it is causing the load to trup your breaker have the pump checked
Sep 05, 2009 | Oase BioTec 10.1 Filter
OASE fountain pump fluctuates height every other day.
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
Jun 21, 2009 | Little Giant Submersible Fountain Pump
Oase BioTec 10.1 Filter Logo
606 people viewed this question
Top Oase Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Oase Pool and Spa Expert? Answer questions, earn points and help others
