Question about GE Energy Star WCVH6260F Front Load Washer
Cleaned trap; but still won't drain...
I had the same problem many others described her...namely after about 18 mos. of use, the washer started to pause randomly during a cycle, sopping wet clothes, etc. I was RELIEVED to see the solution posted that helped so many....i.e. opening the front panel, cleaning out the drain trap and the tubing around it etc.....I did and there was a ton of gunk, coins, etc. Only now, when the washer during a cycle gets to the point where it should drain or spin, the little motor (or electrical component box) immediately to the right of where the trap joins/links to the drain hose clicks, hums gets VERY hot to the touch.....then clicks again as if it has overheated.....then the washer cycle "pauses" again right away and the door unlocks. Anything else to try? Does it sound like this electric gizmo is burnt out? I tried unplugging the machine overnight to see if that helped but no luck.....any help/ideas? Thanks!
  • SoggyinCincy Apr 27, 2008
    Also, I checked the impeller on the motor/pump...it doesn't rotate very freely (only about 3/4 turn and only with some pressure). I checked this as best I could without removing the pump.....would it be possible for there to be any blockage that is only visible upon removing the pump? I don't see an easy way to remove this pump but will keep checking..........
    President:
  • 1,294 Answers
Surely your pump is clogged, which you should dismantle to check or replace.
A very important thing for all front loaders, all pockets should be checked before dumping in machine, small items should be placed in pillow case or special plastfc bag - so they don't slip into inner drum by accident, and clog pipes, etc.
Posted on May 31, 2008
Hotpoint WDD960 F13 code, water not pumping out.
hi if you wash small childrens clothes such as small socks they can get between the door seal and drum. they then get trapped in the rubber hose between the drum and pump which would create the problem you are describing.you would find this hose under the washer.
Jun 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
My bosch washing machine model WFVC6450Uc/19 FD 9002/901476 has E:13 flashing. i was able to drain the water manually but now the door locked there is beeping sound when i try to start it. how to fix it
Hello & Welcome to FixYa
E13 error in your Bosch WFVC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Garbage Disposal is about 2-1/2 years old It is now no longer grinding up potato peels and clog every time! HELP--do we need a new one!!!
1/2 horsepower is the lighter weight model, and if you use it heavily, then it will not work like before.
Another thing to consider is whether the water is draining away completely while you're cutting.
If water and potato peels are both present, your p-trap and tubular drain may need to be cleaned.
Let's go through the whole thing: replacement, p-trap, tubular pipes, everything.
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or move pipes around.
How to replace disposal body: Disconnect both nuts on p-trap. Remove p-trap and loosen tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you might want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both nuts on p-trap, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water backing up in the drain pipe
many washers have a lint trap just before the pump
the traps get full of socks, lint, or other small items
those that dont have traps, should.
examine the hose between pump and trap and drum, for trapped small items
to see the hose and trap
kenmore whirlpool & heaps of others
Unplug washer
turn off taps
  • remove trims from edge of control panel
  • remove screws from under bottom edge of trims
  • raise slide forward and flip control panel over, hinged at top, do not dislodge air hose to level control
  • remove brass body clips under control panel, not position for reinstall
  • lift body 1/2inch (locator studs at bottom) and remove, top front and both sides come away as one piece
motor pump gearbox tub suspension is now exposed
reassemble in reverse order
Dec 05, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
171 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
