Question about Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier
Master volume crackels from left to right - Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier
  • Marshall Amp... Master
  • 5,603 Answers
The master control has one of two problems:
1. It is noisy. Get some CRC226 in the electrical dept of Home Depot and open unit and spray a small amount into the control through the back side where the leads go into the pot. You may need to bend the spout of the CRC226 can to get it into the slot. Turn the pot back and forth to distribute the product on the resistance element inside.
2. The solder of the leads of the control has broken. Resolder these leads.
Posted on Aug 07, 2010
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
Master volume is scratchy on MG100FX
All i can suggest is to use electrical contact cleaner on it from the inside. But you,ve already done that. And i would imagine that the master volumes will be the same to, Harry
Dec 28, 2013 | Marshall Music
Some keys on the left side are not giving sound when played and the master volume is loosing can it be fixed or should i have to buy a new master volume
It's about hardwares.
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Jul 31, 2013 | Korg Pa50 Professional Arranger Keyboard...
How do I connect my laptop to my numark icdmix3
If you want to mixdown onto your laptop, get a cable with RCA left and right on one end and an 1/8 headphone jack on the other. On the back is a master out w/left + right and go to line in or mic input on laptop. If you don't have a line in, you have to disable the mic signal +4 db setting in control panel/audio properties volume control. Open properties there and add mic volume control, and open advanced to turn off +4db setting.
Mar 04, 2013 | Numark Industries Numark iCDMIX 3 Dual...
Not reconizing input of guitar
Read your manual good and check settings. Look for master volume and pan outputs. Make sure it is connected properly to you amp. You have a left and right output, also check the amp/line switch. You can find your manual here http://line6.com/support/manuals/
Mar 03, 2013 | Line 6 Floor POD Plus Guitar Multi Effects...
Crackel from clavinova speekers
Open up the cabinet and spray some LPS1 or contact cleaner on the volume control and the head phone jack- runt hem through their paces a few times to make sure the contact surfaces are clean.
This should remedy it.
Jan 27, 2012 | Yamaha Music
No Monitor output.
What model system do you have? If it is the PD250 what position do you have the Stereo/Dual selector switch in? It should be in Dual mode and the Left master volume control will control the monitor volume. The internal reverb will only be sent to the Main speakers.
Aug 17, 2009 | Fender Passport Deluxe 500watt Sound...
How to use the four ouputs in korg pa800
Go to www.korgpa.com/pa_root/pdf/pa800/Pa800-200UM-ENG.pdf.Page 226 has the audio output section.Page 19 has the rear panel explanation. Left/Right: These are the main stereo outputs. Use them to send the final stereo mix to an external device. Connect either to get a mono output. Set the output level with the Master Volume slider. 1/1: These are the sub outputs. Use these to create a stereo submix of just some tracks or to output just a single instrument to be mixed alone or to be processed or amplified externally. Not: the Master Volume slider has no effect on these outputs. Signal is sent dry with no effects applied. Hope this helps.
May 22, 2009 | Korg Pa800 Synthesizer
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier Logo
130 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
