Question about Exercise & Fitness
The digital timer comes on but it does not show advance to show your accomplishments. The count, remain at zero.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 11, 2010
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 10, 2015 | Oxo Good Grips Digital Timer
How do I change the clock on a oxo digital timer?
I'm assuming that you're referring to OXO's Digital Timer Model #1061978. OXO doesn't provide a copy of the instruction booklet for download, but I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Aug 19, 2014 | Hardware & Accessories
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
Freezer was not working this morning and the air does not seem to be as cold as normal that is coming out of vents from inside. Wasn't sure if door was left cracked open, but it hasn't seemed to...
Test Defrost Timer # 9 in this download http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28327585&pkw_=basket&model_id=5167318&NewWindow=1
The defrost timer is usually found in the temperature control console.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode.The freezer fan motor should have stopped now in defrost mode. Simply wait about 35 minutes and check whether it has moved out of defrost mode and has resumed cooling (listen for the compressor and freezer fan motor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multimeter. Set the multimeter to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the white wire in the connector plug.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multimeter should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Sep 18, 2011 | Amana ACD2232HR Side by Side Refrigerator
When in auto dry mode, the heat comes on for an initial warming but then does not come on and the dial does not advance. When using timed drying, the dial DOES count down but heat does not come back on...
It sounds like you have a faulty timer. To test it, remove timer knob and remove screws. Remove screws from behind control panel. Disconnect leads from timer motor, use a Volt/ohm meter and probe leads, if reading is high or infinity, it's faulty. Should range between 2 or 3k. You can also test the temperature selector switch. It's located next to start switch. Take off leads, probe with meter, Turn switch, reading should range from zero to infinity or vice versa.
Apr 12, 2011 | Dryers
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Warm fridge, cold(er) reeezer
we ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
Aug 20, 2008 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Tag Timer Resets to Wrong Time
Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
Nov 04, 2007 | Tag Heuer Watches
Exercise & Fitness Logo
26 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
