Question about Miele 36 in. KM342 Gas Cooktop
Miele KM 342 - I have burner - will ignite when knob pushed in but once release knob flame goes out
    Scholar:
  • 91 Answers
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
Posted on Sep 02, 2010
A gas ring does not remain lit after lighting on one of the burners on my Borsch brushed steel gas hob
Seems like one of the thermocouples has failed or it may just be dirty. There should be 2 "prongs" sticking up toward the burner. 1 is for the ignition and causes the spark to jump to the burner and light it. The other is a thermocouple which senses the heat from the flame and operates a magnetic device on the gascock to keep the gas flowing. If the thermocouple is faulty, damaged, dirty, it may not sense the heat and therefore, the flame will keep going out. Make sure the end of it is clean and the burner is positioned properly on its base. The thermocouple is usually a steel rod sticking up. This can be easily cleaned with a bit of steel wool or scourer. Do NOT scrape or scour the ignition prong as this is made from porcelain and can break very easily. It is usually white in colour, with a little metal cap or stud on the end. sometimes , the knob wears and you cant push it down far enough to lock the magnet when the flame is on. Pull the knob off and try stuffing a little bit of paper down the hole in the knob which goes onto the gascock shaft.. This will allow you to push the shaft down further and thus ensure the magnet is locking onto the gascock. If you are unsure, try a knob from one of the other burners that you are not having trouble with and see if that works, if it does, then you know its the knob, Cheers, Steve
Jan 05, 2015 | Cooktops
Gas burner will not stay lit. works fine when pressing knob for igniter function but goes out when knob is released
You have what we call a flame safe device fitted to the burner, (thermocouple lead), have you checked to make sure your flame on the burner is touching the tip of the "probe" on t'couple, if it isn't make sure that the ports on the burner are clear. If this does not solve problem then the thermocouple needs replacing by a Gas Safe engineer.
Oct 25, 2013 | Verona VEFSGG365SS 36" Gas Range with 5...
I have a Miele double burner combiset gas cook top and one burner ignites, can see flames but when leave the knob, it goes off. Flame doesn't stay on. What could be the problem? How can I fix it?
Need to use a small pointed object like a toothpick and stick in each small hole that flame comes out of on Brunner to clear jets.
Oct 13, 2013 | Cooktops
I have a Miele cooktop and often during ccoking another burner starts clicking and click for a long time......solutions..... Also the lower left burner goes on for may be 10 seconds while clicking, the...
I have the Miele km342g cooktop. The ignition would continue firing intermittently after the burner was lit - click, click, click. Drove us crazy for years and we cursed the unit every time we used it. We assumed it was sensing unburned fumes and so we bought a small fan to "whisk" the gas fumes away. etc. etc. I finally figured out what a simple little thing it was. To start the burner, you turn the knob counter-clockwise. Therefore, once the burner is lit it's intuitive to turn the burner down by turning it clockwise. But in order to turn the burner down, you have to continue turning it counter-clockwise - or, "counter-intuitive". Once we figured that out, we haven't had a problem since.
Sep 04, 2011 | Miele 36 in. KM342 Gas Cooktop
Electric ignitors clicking
I'm sorry that I don't have a solution for you, but my Miele gas stove does the same thing. I had a repairman come out while it was under warrantee and they fixed it, but it was only temporary. It's doing it again, but, of course, it's no longer under warantee and will be very expensive to have Miele come out again. I've found that it's the right front burner that causes the clicking, so I've just stopped using it.
Apr 18, 2010 | Miele 36 in. KM342 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Nov 10, 2007 | Miele 20 in. KM405 Gas Cooktop
Miele 36 in. KM342 Gas Cooktop Logo
615 people viewed this question
Top Miele Cooktops Experts
Marvin
Marvin
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
