Question about Makita 2703 10" Table Saw, Electric Brake
Switch wiring for makita cut off saw - Makita 2703 10" Table Saw, Electric Brake
    Problem Solver:
  • 8 Answers
Go to makita.com enter yr model # in the search bar, down load a parts breakdown, it should b there
Posted on Aug 18, 2010
I have changed the armature (windings) on my makita BCS550 18v metal cutting circular saw but now it is going in reverse, any help greatly appriciated.
I believe the motor is a brush style unit (only an educated guess) I would revers the wire going to the armature. Most small brush style motors are polarity sensitive.
Feb 20, 2013 | Makita BCS550 18V Lxt Lithium Ion 5 3/8...
Wiring diagram for switch on makita mlt100 saw
ring Makita on 01908 210710 and ask for technical
May 30, 2012 | Makita Saws
Makita JR3000V stopped working
I would have checked the cord first. Cords are a high failure part because they always get bent and pulled and such. Some versions of the jr3000v had problems with field wires breaking right at the field terminal.
Mar 05, 2012 | Makita Saws
Makita petrol stone cutter
Start by removing the wire from the cut out switch to rule out a problem with the switch, if still no spark with a new plug it will be a replacement ignition unit.
Feb 12, 2012 | Saws
Makita 2414db saw does not turn on
The smell test would probably find a burned out motor (one that had overheated and melted the insulation on the wires of the motor coils), but it won't find a shorted motor coil. Use an ohm-meter to compare the resistance of each coil. Try a pair of contacts (where the brushes normally rub) that are opposite each other, or nearly opposite each other. When you find a reading, repeat this pattern all around the motor. Your readings shouldn't vary by more than a couple of percentage points, but if the motor is toast you will probably find a very large variation in the readings.
Feb 25, 2010 | Makita 14" Portable Cut - Off Saw 2414NB
Wiring varible speed swith for a Makita JR3000V reciporcating saw
The replacement switch, is it Makita and was it a direct replacement for the original part? That could make a difference. I looked at the schematics for this tool and they do not furnish the wiring codes but I think you are on the right track. To make sure though I would call Makitas tech support people at 1-800-4625482 and have a wiring explosion sent to you. Let me know if you still need more help and I will contact them or call a local dealer that I know.
Jul 24, 2009 | Makita JR3050T Recipro Saw 9 Amp
Makita table saw switch wiring
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Mar 01, 2009 | Makita Saws
Makita 2703 10" Table Saw, Electric Brake Logo
309 people viewed this question
Top Makita Saws Experts
Marvin
Marvin
ray gallant
rlev_7
Level 1 Expert
Are you a Makita Saw Expert? Answer questions, earn points and help others
