Question about Dell Computers & Internet
When I power up my monitor the display briefly flashes on - to the login screen - and then the display goes blank. If I use the power switch to turn the screen on and off the same thing happens - brief display and then nothing. Can anyone suggest a solution?
  • 225 Answers
Open the monitor, look for blown capacitors and replace them. If problem persist, test the light bulbs and the inverter. If the inverter includes ceramic capacitor, replace it. If some of the bulbs does not do the flash - replace it. Check the transistors of the inverter. Replace if faulty.
Posted on Aug 07, 2010
Blank computer screen 3 times out of 4 when booting computer
there must be the problem of your lcd backlight chek that properly by open it or tack it to the engg.near you.
Jan 27, 2010 | Samsung 226BW Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor powers briefly then goes blank
Sounds like a Control board issue or a Power board issue... Might be blown Capacitors, in which case there is not enough power being supplied. Check to see if there are cheap parts on Ebay as replacements. If you don't want to go through the trouble sell the LCD itself for $150-250.
Dec 18, 2008 | Sony SDM S81 18 in. Flat Panel LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
Computers & Internet Logo
170 people viewed this question
Alun Cox
