Question about LG Televison & Video
Burning smell inside TV and TV is not working
  • joecoolvette
    joecoolvette Aug 07, 2010
    Take the TV to a repair shop, or discard the unit. There are Voltages inside that can give you a FATAL shock. You need to be qualified enough at least to have the tool, and proper knowledge, to discharge capacitors, for starters.
  • 27 Answers
If it is under warranty do not touch take it back to suppliers.
Check components, inturnal fuses look for burn marks on the PCB's most good electrical stores will sell new companents and soldering irons, if tracks are damaged you can solder wire to replace routing.
Take it to an electronics repair store if you don't want to take it on yourself, if you have insurance and it is beyond economical repair pay the excess and get a new one.
Posted on Aug 07, 2010
Whirlpool over microwave combo has burning smell in microwave
Probably fragments of food burning on the waveguide cover.
Jul 31, 2017 | Microwave Ovens
I have a 1990s JVC tv that we were wattching the other day then we smelled a smoky smell. Then horizontal lines and staticy sound started to go through the tv. We tried canned air to clean the vents a few...
That tv is very close to catching on fire. UNPLUG IMMEDIATELY. When electronic equipment is old they dont just stop working sometimes. Sometimes the electrical current starts burning the wires and the dust inside. there is a definare odor to electronics burning or shorting out. smell around the air vents in the back of the TV. youll know if wires were burning its a distinct odor
Jun 03, 2012 | JVC Televison & Video
Burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Apr 04, 2012 | Samsung HLP6163W 61" Rear Projection...
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
Just replace the lamp.. there is a burning like smell, does anyone know what is causing this smell?
After the projection lamp was replaced the tv work fine right?The burning smell,is the burning carbon from the dead projection lamp.
Oct 06, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
Burning smell on right side (facing tv)
contact a repairer ur wire inside tv has burnt
Sep 03, 2009 | Philips 30PW8420 TV
BURNING SMELL COMING FROM MY WASHING MACHINE
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Aug 05, 2009 | Washing Machines
No picture
Burning smell can be caused by a blown component, a short, or dust burning inside circuits.
In all cases do not turn TV on untill the TV had been tested and the problem is fixed as you risk to cause further damage to the unit.
Regards.
May 17, 2009 | Mitsubishi VS-5046 50" Rear Projection...
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Akai tv has failed to work
There are many circuit areas inside a TV set that can have burning components. Since you describe a colour change, I would think the fault may be in the video processor, screen biasing, or video drive path.
Jerry G.
May 22, 2008 | Akai PT4799HD Rear Projection Television
Televison & Video Logo
97 people viewed this question
