Question about Toshiba Satellite M105-S3084 Notebook
Hi team, I have toshiba satellite m105-s3084 its clock was not working from a long time, now display is not working,in starting of this problem when I open display flap it works for a few second then dim and then off, but now it is not working..finally off. what should I do? if I want to sale it how much should I aspect? please suggest thanks n regards piyush
    Novelist:
  • 115 Answers
The CMOS battery most likely needs to be replaced. This can be a daunting task even for a pro. The CMOS battery is most likely a CR2032 watch battery that you can pick up at almost any computer repair shop or even a **** store in the battery section... even at a home supply store where they have replacement batteries for garage door openers.
However, getting to the battery, which is mounted on the motherboard can be very difficult to get to and should only be attempted by a professional repair shop.
My advice? It's probably time to just toss this laptop to the recycle guys (you might want to pull out the hard drive first and mount it into an external case if you want to retrieve files from it... or destroy it with a drill if you don't).
To illustrate just how difficult it can be with this model of Toshiba Satellite, I've included a video link. I think you'll get the picture.
https://www.youtube.com/watch?v=AfHAbAcMKlE
Posted on Sep 20, 2017
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: cant get pass bio screen on satellite m105-s3084 toshiba
The Toshiba BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work. There is a hardware hack solution (a dongle) to remove the password.
Buy a 25 pin male D Sub connector and join the following pins together by soldering wires to these pins. Make sure the wires do not short against each other. The pins are numbered on the connector.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle into the printer port of your laptop and power up the laptop. Press F2 function key to get into the BIOS and then remove the password. Your laptop should boot up without the password and you can remove the dongle.
Posted on Feb 10, 2009
buffalonyman
  • 1865 Answers
SOURCE: The sound on my satellite m105-s3084 stopped working
Go to device manager, if the sound card has a yellow exclamation point near it, then the driver is at fault. You can simply reinstall the driver or remove the sound card and restart the computer. Windows will discover the sound card and install the driver
Posted on May 02, 2009
Elessaelle
  • 122 Answers
SOURCE: hi . i have toshiba
Here is a list of compatible processors for your notebook. Just click Processors in section Compatible products and you'll see which core 2 duo processors are supported.
Posted on Sep 05, 2011
Testimonial: "thanks. what core 2 duo processor (hopefully incease my notebook with the highest speed) will elessaelle sugest? i'll upgrade my RAM too into 4GB."
Hi . i have toshiba satellite m105-s3084. i really need to upgrade my notebook performance. can i upgrade my processor into core 2 duo? thanks. (anwar_aim@yahoo.com)
Sep 05, 2011 | Toshiba Satellite P100 Notebook
After the change of cmos battery it ask me password but i forget and it does not boot any device
Hi gavossevou...
You will need to start your computer in the "Safe Mode", you do this by tapping F8 while the computer is starting up.
Once the computer has started, select "Safe Mode".
Once you are in the safe mode, then you will double left click on "Start">Control Panel>User Accounts>Change an Account.
Now you can change your password,delete the account,etc.
Please take time to rate me
Aug 16, 2011 | Toshiba Satellite M105-S3084 Notebook
Bios password
This is a know issue with Toshiba laptops,
  1. Try the passwords listed here.
  2. If that doesn't work, you will need to send your laptop in to Toshiba, they will charge you if you are not under warranty, unfortunately, they do not reveal the master/reset password or procedures to others.
Jul 04, 2011 | Toshiba Satellite M105-S3084 Notebook
Toshiba Satellite M105-S3041 clock problem
Chances are your CMOS battery is dead, it can be replaced inexpensively if you do it yourself. After taking the laptop apart, locate the battery, it looks like a large watch battery. When you remove it, note the battery type and run to your nearest battery store for a replacement.
Jul 07, 2009 | Toshiba Satellite M105-S3004 Notebook
May 02, 2009 | Toshiba Satellite M105-S3084 Notebook
Cant get pass bio screen on satellite m105-s3084 toshiba
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Feb 10, 2009 | Toshiba Satellite M105-S3084 Notebook
Toshiba m105-s3084
Number of Slots:
Slot 1 Slot 2 Normally you will find the 2 slots, one above the other.
Each memory slot can hold DDR2 PC2-5300,DDR2 PC2-4200 with a maximum of 2GB per slot.*
*Not to exceed manufacturer supported memory. Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules. Make sure that both are fully seated prior to powering up the laptop.
Nov 05, 2008 | Computers & Internet
The clock on my Toshiba Satellite M105-S3064 has never been correct and it is creating a lot of problems with my Outlook and synchronization of my phone.
Go to BIOS and set the time correctly.
If it starts losing time again, you may need a new CMOS battery.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 28, 2008 | Computers & Internet
Toshiba Satellite M105-S3084 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
