Question about Keurig Special Edition B60 Coffee Maker
After several descaling processes and a new kcup holder the machine is still slow and sometimes only fills half the cup. After descaling, the symbal goes away only to return after only a few uses. I have descaled with white vinegar probably 4 times in the last few weeks.
  • Keurig Master
  • 1,711 Answers
This problem can be seen on the following tip
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
good luck
Posted on Aug 10, 2010
Keurig problems
what is your model and serial num ?
Sep 02, 2017 | Coffee Makers & Espresso Machines
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
Cup not filling up
There are 3 needles on the underside of the lid and one on the bottom of the kcup holder. Using a thin "uncoated" paper clip, straighten the clip and insert it into the hollow needles and then run a 4oz cup of hot water (NO Kcup}. Repeat until NO more grounds are dispensed. Dave
Mar 04, 2014 | KUERIG Keurig Platinum B70 Brewing System
Keurig exploded k cup & very slow to brew
The water tube needs cleaning and the lower holder also. You have a clogged system and it needs cleaning.
Feb 06, 2013 | Keurig B60 Coffee Maker
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
B-60 Keurig. Does not give proper fill. The steam is weak.Stops in the middle of the filling cup process. Works fine if I just run water through it. Have descaled numerous times per Keurig instructions. I...
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Feb 10, 2010 | Keurig B60 Coffee Maker
MY b60 all of a sudden won't fill a full cup when it brews. I descaled it and it works just fine and fills the cup with water and no kcup in place. When I brew with the kcup it only half fills.what can I...
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
Dec 30, 2009 | Keurig B60 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
193 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
