Question about Electrolux 23 in. ESI6104 Built-in Dishwasher
Our electrolux ESI 6104 is operating ok but the water is not heating up. We assume its either the Thermostat or the element - how do we know which one it is? Any advice would be a great help. many thanks
  • rosiewesti Aug 07, 2010
    Took out the thermostat and put it back in and now water seems to be heating up!!
    Obviously a loose connection!
Hi, we have the same problem with the same dishwasher - but I can't find the thermostat??? Where is is????
Thanks
Posted on Sep 05, 2010
Electrolux esi 6104 cycle not finishing and not heating up
Good Morning Ryan,
I understand that you are having trouble with your Electrolux dishwasher, model# ESI 6104, not finishing the cycle and not heating up. I will be more than happy to assist you. From the model number provided, I show that this was made in the UK. I have done some research and have been able to find the UK Electrolux telephone number. If you call 08445 613 613, they will be able to better assist you in why your Electrolux dishwasher is not finishing the cycle and not heating up. Hope this is helpful.
-Best Regards-
WP
May 11, 2014 | Dishwashers
How do i check serviceability of thermostat and heating element on bosch dishwasher
Is the dishwasher connected to the hot water line? It should at least get hot water when it initially fills and then keep it hot when it operates.
May 06, 2014 | Dishwashers
Water does not heat
it could be your thermostat or heater the only way is to test both with a mutimeter on ohms and you should get a readihg if ok no reading means one or both have gone open circiut
Nov 24, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwasher stopped heating. PCB is fine with no signs of damage. Is there a resettable thermostat or is it a bung water heater?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 28, 2011 | Electrolux Dishwashers
Not Heating Water /Element OK all other functions work
Check thermostat. Follow the heater wire bunch, you will reach two points.
1. Thermo switch
2. Control circuit connection.
Sep 20, 2010 | Electrolux Dishwashers
Kitchenaid KUDM25SH dishwasher - water not heating
Depends on how much that you use the dishwasher. It's possible that the element is burnt out. If you know how to check the element, you can with a meter, however if you don't know electrical, then by all means get a qualified individual. There isn't a thermostat. Everything is on a timer circuit.If there is a preheat on the machine, you could set it to that and the element should come on also.
May 03, 2017 | KitchenAid 24 in. KUDS25SH Built-in...
My electrolux ex302 not working the water is not
You may have an issue with the heat element or thermostat (if applicable). Contact an appliance service company.
Feb 20, 2010 | Electrolux Dishwashers
Electrolux ESI 602 will not fill with water
The float better be inside the tub, at the bottom, it usually only travels a couple of inches up and down... you may have a protective cover in the way of it.
Jul 26, 2009 | Electrolux 23 in. ESI602X Built-in...
In built dishwasher, Electrolux ESI6220, is not heating the water and therefor not washing the cutlery properly. What may be the problem and how does one remidy same?
You have to test the heating element with an ohm-meter. It should read very low ohms. If the element seems ok, you have to test the controller to see if it is powering the element (probably should be 120 volts)
May 05, 2009 | Electrolux Dishwashers
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Electrolux 23 in. ESI6104 Built-in Dishwasher Logo
395 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
