Question about Samsung ML 2010 Laser Printer
My Samsung ML-2010R mono laser printer has suddenly developed a paper-feed fault. The paper starts to feed through but stops as soon as it reaches the toner cartridge. When it is removed it always has a black splodge across the top edge. It does this 9 times out of 10 now, despite putting in a new cartridge, rebooting, switching on and off. Every 1 in 10 I get lucky and the paper actually goes through the printer and I get a print. I have been happy with the printer up to this point - which is not old. Any ideas? Thanks for your help!
  • iholton Aug 07, 2010
    Fixed. The instructions were mostly correct . The only correction I would make is that the supports are not two supports but a single moulding like a bobbin such that each of the two sides holds the roller in. Therefore it is necessary to lift both tabs in order to pop the roller off.
    This has saved me buying a new printer. Thankyou !!
  • 857 Answers
I can asily say that the problem is a worn
paper pick up roller tyre. This is a universal problem with laser printers and
is related to the number of pages that have been fed.
You can take the pick up rubber and its housing off without removing the shaft. after taking off the front panel and taking out the upper paper tray and the toner you have lots of room to get your hands in there (make sure it's unplugged before you start). two plastic side supports hold the rubber housing in. lift the tab on one and slide it to the side. the housing will now come out . take note of the positioning of all these parts before taking them apart. I sometimes use a digital camera for this purpose. the housing snaps apart and the rubber band slides off. I turned it inside out and put everything back together. works great now (for another year I hope). It's not difficult, it took me about 30 minutes, but be gentle with these plastic parts. I needed a small flat head screw driver and a good lamp. the easiest way is to stand the printer up on its back and reach down inside the hole with the lamp set up over top. good luck.hope this helps.
Posted on Aug 07, 2010
How Do I fix Samsung Laser Printer?
I would suggest using plain denatured alcohol (you can buy at a paint store or a Home Depot type store.
Take out all of the paper and get access to the rollers. Use a q-time or reach in with a cloth (do not use a paper towel) with the alcohol to clean the rollers.
Sep 21, 2014 | Samsung ML-2010 Laser Printer Monochrome...
Samsung ml-4050n very high noise
Check the area on and around the developer assy for paper or maybe a staple ( paper clip )
I would power blow out the complete system and re-assemble.
Mar 26, 2014 | Samsung ML-4050N Laser Printer -...
ML 1865 paper stuck
Just start it up and give the paper a good pull.
Oct 25, 2012 | Samsung ML-1865 Mono Laser Printer...
Sumsung ML-3471ND Paper jam 0 problem
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Oct 28, 2010 | Samsung ML-3471ND Network Mono Laser...
Paper jammimg in our ML 1430 Laser Printer
clean the roller opening the door at the backside of printer...................and if u want our technician support contract us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Samsung ML 1430 Laser Printer
Laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Jan 19, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
277 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
