I just bought a pair of behringer eurolive 315A speakers, but when i play most songs through them i only seem to get half the frequencies of a song, its sounds really wierd. Ive realised im not using the recommended shielded XLR cables. Could that be the cause? Both the horns and woofer seems to be working, just not properly, its not a mixer issue as ive tried with different speakers and they work fine. Whats even more strange is some tracks play perfectly well.
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have a pretty old
I think you're indicating a self-protection problem.
One or more speakers or amps could be going South on you.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 03, 2011
Testimonial: "It worked! Thank you so much! It appeared that one of the extended leads was shorted."
alpug
  • 1961 Answers
SOURCE: my new behringer vmx 200
be sure when you select the chennel 1 input as your audio source you have an audio device plug inn at the channel 1 audio input..
Posted on Sep 11, 2011
just under the phono inputs there is a button for each channel, line/phono, if its pressed in vinyl wont play. press it so it sticks out
Posted on Apr 30, 2013
Why does the fuse keep blowing?
Hmmmmm. Are we talking about your internal or external fuses; Do they blow at the moment you put power on it, and what about the switch of the used voltage ?.... And was it straight away , since when you bought them; Then just send them back, Second hand?, too bad, you're ripped off .
Jul 21, 2014 | Behringer Eurolive B212d-wh Active...
Good time! I am Oleg Ivanov, Moscow, Russia. I have a "Behringer eurolive F1520" floor monitors. Was buy its used. HF drivers are fired. When i get install new HF drivers, on filters plate i see...
Oleg Ivanov!!!
If you from Russia read about the decision of the problem with Behringer EuroLive F1520 here (in Russian)
http://forum.plus-msk.ru/showthread.php? t=136317
my e-mail: nata-levich@list.ru
Mar 01, 2011 | Behringer B1520 Pro Eurolive 15" 2-Way...
I bought a Behringer Eurolive B1220 Pro speaker with my PA system brand new and it sounded great at first. Now it sounds really muddy (the other 2 speakers I bought work fine) almost as if the horn has...
Bad news...you've blown the tweeters. Overdriving the mixer/amp creates distortion on the amplifier which heats up the speaker voice coils and eventually causes damage. Because of their small diameter voice coil windings the tweeters fail first (opens up like a fuse element does) followed by the woofer making a scraping sound (deformed voice coil) or not working as well. Warranty service because you blew out the tweeters? Don't get your hopes up.
1. PLEASE use enough power for the venue that you have. A high powered system will run all night at 10:00 (physical volume knob setting) than an underpowered system set for 2:00.
2. Get speakers off the ground and closer to your audience's ears. Audio from speakers on the floor must battle surfaces that actually absorb some of the sound....carpet, drapes, etc. And besides, legs can't hear that well.
Nov 05, 2010 | Behringer B1520 Pro Eurolive 15" 2-Way...
Behringer B1800 subwoofer quits few times and then stop playing, when connecting a another speaker through the in and out speakon connections the other speaker plays fine, but the sub stays dead
Check the internal wiring. There may be a loose connnection and this is VERY hazardous to you amp !!!
These may also have a self reseting fuse and that MAY be damaged.
You should discover the problem when you open up the unit.
Mar 20, 2010 | Behringer B1520 Pro Eurolive 15" 2-Way...
I recently bought a pair of b212A behringer speakers. when i turn the volume or/and bass past the half way point the clip (red light) begins flashing. Is this a problem and what does this mean
Clipping occurs when an amplifier is pushed to create a signal with more power than its power supply can produce. The red light flashing is warning you that your are overdriving the amplifier located in your speaker cabinets. This can cause damage to your amplifier and or your speakers. You should not allow the volume level to exceed clipping.
For more information on clipping CLICK HERE
Take Care!
Nov 14, 2009 | Behringer Eurolive B212A Speaker
Behringer eurolive b1520 pro speakers duller than the other
Best and safest is to have a good electronicus check it out.
i've worked on these kind off things, and i assure you not everything can be simply solved without experience, especially when talking about a decent type like Behringer ;)...
Hope this is helpful, and greetings,
Olivier.
Oct 22, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
Output volumn low on behringer B212a
Hi...
Swap the input signals...Does the problem move to the other speaker?
If not , it will need a tech to troubleshoot it.
Mar 31, 2009 | Behringer Eurolive B212A Speaker
While playing it (the speaker just quit on me
the same problem in the B300 is fix by changing ic 7815 and ic 7915. Dan
Dec 13, 2008 | Behringer B1520 Pro Eurolive 15" 2-Way...
42 people viewed this question
 Grubhead
Grubhead
