Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
I have an Epson RX 425 scanner/printer.The printer works fine but on scanning a photo a grey line appears across the whole scan. How can this be avoided or is there a cure ?
  • j_m_liddle Aug 07, 2010
    No improvement. The line appears like a peice
    of grey tape, about 1 cm wide , and extends
    across the scan. The glass appears perfectly
    clean.
    There is no grey line when printing from the
    computer.
  • 11,896 Answers
Is this with paper that has been folded or plain flap piece of paper?
Sometimes folded paper can do this.
Another thing that can happen is the lamp lens can get hair or light scratches or dust particles on it. Just little ones will cause the grey lines as well.
Posted on Aug 07, 2010
  • 2 more comments
    No , this is with flat paper. Unfolded.
    They are not hair-line lines , it is a big fat ugly disfiguring line
    about 1 cm across going across the whole scanned picture
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    There has to be something on the scan/copy light or light cover.
  • j_m_liddle Aug 08, 2010
    It all looks perfectly clean. I'm wondering if the scanner is not
    compatable with Windows 7. If this is in fact a possibility is
    there some different software I can download ??
  • Nate Stansfield
    Nate Stansfield Aug 08, 2010
    That was actually me next suggestion. You can go to epson website, find and download the latest drivers. The drivers is what lets the printer and pc communicate with each other.
    They are usually under the download or support tabs,
    Once the file is downloaded, then double-click on the file and it will install itself into your pc.
    Then reboot pc, turn on printer, start your printer program and lastly connect the usb cable.
    They should also have free printer software on their site that is updated as well.
  • 4,323 Answers
Hi
Use a damp cloth and clean the scanner glass and try, if the lines are still there then you will need to clean the scanner module. There might be dust/dirt around the module. Turn off the printer/scanner and unplug it, remove the scanner glass and use a soft cotton cloth dampened with alcohol and clean the scanner module. Blow away any dust from inside the printer.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
I have printer plus scanner epson l200. and I thought there is option for scanning a film. but it turned out the option is greyed out. I wonder if this type is available for scanning film or there is
To scan film, your scanner needs a light above the film. Not just a light, but a calibrated light. That is why the scanners who can scan film and transparent sheets, have a lit with a light in it. Your scanner does not have this, so scanning film is not possible. One of the cheapest (flat bed) scanners from Epson is the V600 and costs about $200, Epson Perfection V600 Photo Scanner
Feb 04, 2015 | Epson L200 All-in-One Inkjet Printer 27...
How do you scan a document using a pc?
The printer can be used for scanning without a computer in sense of the scanner offering a copying facility - in B+W or Colour just by pressing the appropriate button on the printer. However, for scanning via the computer, if you are using a Photo programme (like say Adobe Photoshop or virtually all such programmes) normally you will find under the FILE menu (when programme is open) that you should see a menu item on the drop down menu when you click on FILE something like IMPORT - and the Epson printer will be seen listed in the menu that pops up. If you click on that, the Epson scanner programme will start. Normally there is a simple mode but you can change that to the PRO (or may be called Advanced mode) when you can do things like PREVIEW - which will then scan the document or photo in the scanner - and you can in the PRO mode change such as the resolution, what type of documents and so forth. When the Preview runs, you will see the document appear after the quick scan in the main RH panel. You can use a select tool to select the bit you want to scan if not the whole - most into on this will be in their manual - which you should have on the CD that came with the printer. Anyway - always worth ensuring you have the latest drivers, etc. so go to this link on the Epson website, click on Scanner Driver and Scanner Utility and download and install. Whilst on the Epson website, download the manual for that model as it will answer many queries for you as regards printing and scanning. All such info and software for downloading is under SUPPORT area - you select the region in the World where you live, then search for your printer model. The Epson website will normally auto-detect your computer's operating system to ensure you get the right version of Printer Drivers, other software and so forth. If you have no Photo Programme as yet - get Faststone Image Viewer (free) as an excellent programme. http://www.faststone.org/FSViewerDownload.htm
Jun 25, 2014 | Epson Stylus Multifunction Inkjet Printer/...
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
Epson rx 425 is not compatible with wind 7 cannot add printer to pc
You should be able to install it using built-in drivers of Windows 7, using Windows 7 'Add a printer wizard'
If you have tried this and it does not work then you should refer to Epson, as they claim this is the correct procedure on their website.
You will need to download the Windows Vista version of 'Epson Scan' to enable scanning with your machine, however.
Mar 03, 2010 | Epson Stylus RX425 Multifunction...
Scan button suddenly appears as greyed out
Turn the printer off.Unplug the usb cable.Go to control pannel ans select add and remove.
Remove epson printer software.
restart computer.
download http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58611&infoType=Overview
Turn computer off.
plug usb cable back to printer and turn printer on,start the computer again,should fix the problem.
Sometimes they just get a file damaged.
Nov 11, 2009 | Epson Perfection 4490 Photo Scanner...
Unable to open Epson Scan in 4490
try to uninstall and reinstall your printer software
Jul 17, 2009 | Epson Perfection 4490 Film / Flatbed...
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
Scan problem
try copying a page and see if that works
that will prove the unit is not faulty
if that works unplug the printer uninstall the printer software restart the computer reinstall the printer software and plug the printer in when asked.
if copy doesnt work the unit is most likely faulty
Oct 29, 2008 | Epson Printer
Scanning photos
i just had my CCD replaced before my warranty expired in Feb and it worked fine for a week. Now i'm getting a cyan line down all my negative scans. And since you can only scan negatives in one spot, I can't even use a diff part of the scanning surface to avoid this. Sounds like a downright cheap part and definitely can't do the job. Never buying an Epson again, esp since they closed down the repair center nearby.
Nov 13, 2007 | Epson Perfection V100 Flatbed Scanner
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
