Question about Onkyo TX-SR875 Receiver
Hi i have bought an onkyo ARV 401 amplifier and i
Hi i have bought an onkyo ARV 401 amplifier and i havent bought the loudspeakers yet. does any body knows a loudspeker pair that goes with it. thank you subodha.
    Novelist:
  • 169 Answers
You can choose any speakers to go with your amp as long as
1) they will allow the amp to perform at its best ( impedance and power handling)
Ideally you will buy speakers which will handle the full amps output plus more, then when you turn it up LOUD, you will not break the speakers
2) you still like the sound when they are demonstrated, installed at your home.
Sound is a very individual thing, if you like it then its fine, after all you are the one listening to it most.
Hope this helps
Thanks for using FixYa
Posted on Aug 07, 2010
How do i cpnnect external speakers to my fujitsu siemens laptop
You will need amplified loudspeakers and use a 3.5mm stereo jack to whatever the amplifier/amplified loudspeakers require. Plug it in and there you are.
Jan 07, 2016 | Fujitsu Computers & Internet
How can I connect it to get the most power out of it?
What load is the amplifier designed to drive? It will only deliver maximum power into the optimum load. The loudspeakers are probably 4 Ohms, but the amplifier may well be able to drive 2 Ohms per channel. This means that you need to fit two more loudspeakers This is probably not possible. Alternatively, if the amplifier can be bridged AND can safely drive 2 Ohms bridged or 1 Ohm per channel, you should connect the two loudspeakers together (+ to + and - to -) and connect them to the amplifier output terminals indicated for bridge (often Left + and Right + but sometimes Left + and Right -). If the amplifier can't drive 2 Ohms bridged, do not connect the loudspeakers together, buy another amplifier and connect one loudspeaker to each, with both amps in bridge mode.
Remember that loudspeaker and amplifier power ratings are always massively inflated in the manufacturers' data, often by a factor of 4 and sometimes by 10 or more. You speakers may not be able to cope with a whole amplifier each, so proceed with caution.
Jun 07, 2015 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Onkyo Amplifiers & Preamps
Hi ,try cleaning your volume control ,here is a video so you can DIY or contact your local service. :)
Dec 17, 2013 | Onkyo Audio Players & Recorders
Red light flashes - will not work - could it be dust in the amp?
hi,
its not because of dust. AZUR 640A offers loudspeaker protection if the output of the amplifier goes to a high constant voltage (DC) because of some internal fault. This is a rare fault although detecting it could just save those expensive loudspeakers.
Due to the necessary sensitivity of the DC protection circuit, hard clipping of the amplifier may cause DC protection to be triggered. If this fault occurs switch the unit off, power up again and check
operation with a reduced volume level. If the DC fault occurs again contact your dealer for service.
ok
Dec 29, 2010 | Cambridge Audio Azur 640A Amplifier
Amp protection circuit has been activated
1-check your input cables from connected equipments(cd player or dvd p
layer or any other media source).
2-adjust your input signal level(from-10 db to 0 db).
3-amplifier power must be bigger than total power of all loudspeaker with 20%----(if total power of loudspeaker is 8 watt amplifier must be 10 watt.
Nov 28, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Connect cheap speakers to a new amplifier
You need proper speakers,pc speakers uise mini headphone jacks,wrong termination for an av amp
Dec 21, 2008 | Plantronics MX10 Computer Speakers Use w/...
How powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Oct 16, 2008 | Onkyo TX-SV444 Receiver
No sound through the speakers...
It may be the PS3
you have to select Optical Out 5.1 etc first.
That PS3 is not user friendly at all.
Colin Graham.
Oct 22, 2007 | Audio Players & Recorders
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
176 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
