Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore He3 Front loader error message F11 due to power being interrupted during cycle. Followed steps in manual but did not clear problem
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Washer code F11??? I have a Kenmore Elite front loader
    F11 Serial communication error
    Communication between the Central Control Unit (CCU) and the
    Motor Control Unit (MCU) cannot be sent correctly.
    Possible causes/procedure:
    1. Unplug washer or disconnect power.
    2. Check wire harness connections to the MCU, the motor, and
    Central Control Unit (CCU).
    3. Check the drive system for any worn or failed components.
    4. Plug in washer or reconnect power.
    5. Verify CCU operation by running a Diagnostic test or any
    cycle.
    Service manual and more HERE
    Aug 22, 2011 | Kenmore Washing Machines
    We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
    The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
    If the washer starts to fill but the drum NEVER moves, your MCU is bad
    If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
    If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
    Thanks
    Aug 19, 2011 | Kenmore Front Load Washer
    Error message of f02 on Kenmore HE3 front loader washer at end of cycle
    The F2 error code indicates that the washer spent too long in the drain cycle,that typically is due to the drain pump filter being clogged. It's fairly easy to clean that filter by removing the lower panel and unscrewing the filter on the lower right side .Be prepared for some (perhaps a lot) of water to come out when that filter is unscrewed so have some towels or a couple plastic tubs to catch the water that comes out DO NOT completly remove that screen until all the water has come out or be prepared to get very wet by pulling it out without first catching the water
    Hope this helps and if it does please give me 4 thumbs up
    Gene
    Jul 28, 2011 | Kenmore HE2 Plus Front Load Washer
    I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
    either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
    Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore HE3 front loader shows an error message of F02. It doesn't complete the rinse cycle as a result.
    There is a trap on washer pump I just found to be full of the same **** you find in sink trapp. That is probably why I had same problem. could also be kinked hose or pump issue. The experts at fixya just walked me through it. best ten bucks i ever spent.
    Good luck Scott
    Apr 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Takes almost 2 hours to complete a wash cycle
    Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
    http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
    -Todd
    Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Error Codes F dl and F 11
    Okay...it sounds like you have a bad door latch assembly. It makes contact, washer begins the wash cycle, and then after some vibration becomes unlatched and generates the "Fdl" code or "F11". "Fdl" is a door latch error, "F11" is a serial communications error to the CCU. A door latch problem can generate BOTH codes, because it has a communication link to the CCU. I would recommend replacing the door latch. You can find the part at either repairclinic.com or searspartsdirect.com. Just type in your COMPLETE model number in the Search menu and you will find a listing of all the parts. For instructions on how to replace the door latch, go to my profile and look under "Tips and Tricks". I have a write-up listed there on how to replace a door latch on a front loader. If you cannot find the information you are looking for, or have any further questions, please let me know. I hope this helps you.
    Apr 16, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Error Code for Kenmore HE3
    The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
    Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
    73 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
