Question about Apple iPhone Smartphone
Can not connect you tube problem - Apple iPhone Smartphone
    Problem Solver:
  • 43 Answers
Tip
Brass Tube Fitting
The essential step of tube fitting production include heating, melting, mixing and conveying the raw material into a particular shape. It is important that this shape is maintained during the cooling process. All Brass tube fittings are made in accordance with ASTM standards. All diameters of solid wall Brass tube fittings are continuously extruded through an annular die. Thermoplastic fittings are either injection or compression molded. They are fabricated using section of pipes or machined from molded plates.
Om Tubes Brass Tube Fitting connects different types of tubes to one another. It can be used for in-line, offset, multi-port, and mounting configurations. Various tubing sections like pipe, hose, or other components are connected through tube fitting. Usually the system is configured with straight sections connected by fittings or some specially formed connections and joints. Om Tubes being Brass Tube Fittings Distributors provides you with best quality & services. Products at Om Tubes are of various wall types and all are produced in accordance with the requirements of a variety of industry standards and specifications like ASTM and AWWA. We sell Good Quality Brass Tube Fitting at Om Tubes.
http://omtubes.com/brass/brass-tube-fittings
on May 08, 2017 | Miscellaneous
Can't remember where each plastic tube connects on carburetor, Part Number 530071775.
the small tube hooks to the carburetor. the larger tube connects to the primer base. hope this helps.
Nov 21, 2015 | Garden
Vf750c
I to am having gas flowing from the Air Vent Tube "No. 6" The Air Vent Tube is connected to a "T" Connection, that branches into, the top of the Carbs. I refered to the Honda Service Manual. It stated to connect the Vent tube to the Carb. But which one and where? So I looked at the photos. no doubt. a puzzle to try to figure locations and angles.....but I cold find no cconnection for the No 6 Vent Tube?
Jul 06, 2013 | Motorcycles
Where do the fuels connect from fuel tank on husqvarna 326l
You should have 3 tubes, a fuel delivery tube, a fuel return tube and a fuel suction tube, the fuel delivery tube ( the one with the fuel filer on in the tank ) goes to the connection on the carb nearest to the pump cover held with a single screw, the other connection on the carb goes to the suction side of the primer bulb ( the shorter of the two connections ) the return to tank tube fits to the longer connection on the primer, this tube is just pushed into the top of the fuel tank,
Dec 29, 2012 | Husqvarna 28cc Gas Line Trimmer
My 2005 Equinox has a broken EGR tube, I need to get a replacement tube. Can you please get me the part number?
My tube broke several years ago. The original tube is longer than the replacement. Evidently the GM was unable to make a long tube that would not break. You have a long tube if the input of the EGR (where the tube connects) is higher than the output (where the EGR connects to the intake manifold). If you have the longer tube, you must purchase a replacement from GM which is $200 and includes the short tube, new design EGR valve and a new connector to replace the old EGR electrical connector.
Nov 07, 2010 | 2005 Chevrolet Equinox
Leaking water from metal tube going down front of motor . what is this metal tube for
Thee tube that you are referring to is the tube that connects the radiator via a radiator hose. Assuming that the radiator hose that you have is the black one that feels like thick cloth. You might have a loose connection on the hose and the metal tube.
Jun 04, 2009 | 2000 Ford Escort
I have a tube comming out of the air filter and
Sounds like a oil vent tube double checj=h that the tube is not supposed to be connected to the crank case to help with ventilation.
May 05, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
Engine Coolant Leak
That sounds like the heater bypass tube. On the end of the tube going into the water pump is an o-ring. Pull out the tube, clean it real good, put a new o-ring on it. Clean the hole well that it goes in. Then I will put a slight amount of silicone around the o-ring. That helps it go back together and fills any imperfections.
Hope this helps you.
Apr 03, 2009 | 1999 Dodge Ram
Apple iPhone Smartphone Logo
50 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
