Question about Hoover Dryers
Can I mount the Hoover 3525D dryer upside down?
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Hoover clothes dryer 3.5 kg 3525D stop working
If it does not even start then it is power supply.
If it stopped running at all then it is probably the motor.
If it runs but not dries is the heating element to be replaced.
Post make and model to get parts and diagrams
Posted on Apr 23, 2008
SOURCE: Hoover 3525D clothes dryer
The most likely cause is a faulty start capacitor. I obtained a new one for $22.00AUD from a local spares shop. You have to remove the back and then the motor mounting plate to get access to it as it is behind the mtr when viewded from the rear I had to remove the long wires from the connector block to attach the replacement directly. You will also need a cable tie to attach it.
Be carefull and make sure the dyer is unplugged as lethal voltages are present.
Good luck
Posted on Dec 15, 2008
SOURCE: Hoover 5010D dryer
There should be two rectangular holes about 2mm wide and 10-12mm long. There is a wall mount bracket [D470] which you install against the wall and then the hardest part is getting the dryer on the bracket.
Obviously when installing the bracket make sure that the wall and the screws can hold at least 30kgs.
Posted on Dec 31, 2009
Apr 23, 2008 | Dryers
How do i fix dryer to wall ?
You cannot mount a dryer on a wall OR mount in on a wall upside down. Unless it has been specifically made for this purpose...which is very unlikely.
Feb 25, 2016 | Dryers
Hello, i have a hoover dryer, model 5030D, secondhand, it is just been purchased my us. we put on our first load on and the machine stopped within 15minutes. we noticed then that the machine was...
Hi, if I remember correctly this model originally came with 2 faceplates so the controls can still be easily accessed, when the dryer was installed upside down on a wall. Most dryers can be run upside down, or even on their side as I done in the past with my Hoover 5030D, so the problem would lie elsewhere.
Dec 26, 2010 | Hoover Dryers
Is it possible to mount the unit upside down on wall brackets, and of course, the dryer still operates satisfactorily? As there does not appear to have pressed openings on the rear panel for bracket...
Hi Don.
All appliances must be installed, used, and also transported and stored with the top side up.
If the dryer is turned upside down the weight of the drum, motor and other parts will not be sustained anymore by the rollers and other structural parts located inside the appliance.
The dryer will start, but it will break down after a short usage.
There are also other safety issues involved.
The dryer cannot be installed upside down.
Regards.
Feb 26, 2010 | Hoover Dryers
Hoover ensign 330 clother dryer -upside down install??
No it is not ok to install it upside down the bearing are not designed to work inverted
Jan 26, 2010 | Hoover Dryers
Hoover 5010D dryer
Jul 18, 2009 | Hoover Dryers
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Installin an old Hoover dryer
All the dryers I have worked on you CAN NOT put them on there sides or upside down, check with the manufacturer
Feb 03, 2009 | Dryers
Good luck
May 05, 2008 | Dryers
Dryers Logo
251 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
Marvin
Marvin
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
