Question about Sunbeam SCA103RWB1 Room Air Conditioner
Variable speed fan motor for carrier ahu model # fe4anfoo2
  • 3 more comments
  • ill do it Apr 27, 2008
    cant find the solution is it ti call carrier?
    to call carrier
    i dont need a motor as yet i need to trouble shoot it first
    i need to trouble shoot the variable speed controls. module on motor or control board in control box in ahu.are there certain things to do to test the system without having elaborate equipment on hand. carrier trane tempstar lennox they all have veriable speed motors are they all the same?
    i checked the system its ok.its a carrier infinity system r410a. outside air temp all are ok the motor runs on startup it must give up after running awhile i get a call it stopped running at night. thanks
How do i adjust the control do i set on 69 or want so my room can be nice and cool i do not no how to set it.
Posted on Jun 26, 2008
  • 19,396 Answers
  • 4 more comments
  • Ginko
    Ginko Apr 27, 2008
    Sorry, here is the right link http://carrierrepairs.org.uk" target="_blank" rel="nofollow" >Carrier Air Conditioning replacement parts
  • Ginko
    Ginko Apr 27, 2008
  • Ginko
    Ginko Apr 27, 2008
  • Ginko
    Ginko Apr 27, 2008
    If you let me know your location I can find more contacts
  • Ginko
    Ginko Apr 27, 2008
    Ok, what is the problem is the motor is slowing and speeding without reaching temperature? Or is dead?
    The motor starts and shut down itself, this can be normal if your conditioner keeps programmed temperature.
    If it starts and stop or display weird behavior (but you hear it is working) and do not reach temperature then usually it is either thermostate or control board.
  • Ginko
    Ginko Apr 27, 2008
    If you notice that thermostate is turning conditioner on and off every minute , for example, it can also be due to external heating condition. If it is ir conditioners running into a small space, or is near to an heating source (owen etc), it tends to cycle more rapidly. Try
    to direct the airflow away from the intake so that no cold air reenters
    the unit. This will allow more cooling before the thermostat cycles.
CAN WE INSTALL AN VARIABLE FREQUENCY DRIVE ON CARRIER AC MODEL no. 38LH-100S
No, the compressor is not made for a VFD or the condenser fan motor!
Mar 09, 2016 | Carrier Heating & Cooling
My Blower starts and stops early causing the lines to freeze up.
Your fan motor might be on the way out, and causing the motor's internal overload to trip.Try feeling the fan motor with the palm of your hand after it trips out.If it's hot (without using test instruments), then I'm willing to bet that fan motor is defective. If it has a variable speed ECM motor, it could just be the electronic module on the back end. some manufacturers will allow you to buy the module separately.If it's an ECM, contact me after you get an ohmmeter and I'll walk you through it. I have a simple inexpensive fix
Aug 03, 2013 | Carrier XHB123D X/Y Series Heat/Cool Air...
Can you use a 410 AHU with a r22 condensing unit
Yes you can if the 410 a/h is new just put a r22 txv on it I have personally done hundreds of them mainly carrier they even sell the conversion txv.
I'm a 15 year hvac sub contractor and I know my sh##
Apr 09, 2012 | Carrier 38CKC036 Air Conditioner
Engine light came on and car is over heating. Took it to auto zone and was told it's the fan relay. Its a 2003 PT Cruiser, Turbo. I opened the fuse box under hood. There are 3 spots for relays in there...
Turbo Radiator Fan
The radiator cooling fan is a variable speed electric motor driven fan. The radiator fan assembly includes an electric motor, fan blade, and a support shroud that is attached to the radiator. The radiator fan is serviced as an assembly (fan motor/fan/shroud).
The variable speed radiator fan is controlled by the Powertrain Control Module (PCM) by way of a Pulse Width Modulated (PWM) signal. The duty cycle ranges from 30% for low speed operation then ramps-up to 100% for high-speed operation. This fan control system provides infinitely variable fan speeds, allowing for improved fan noise, A/C performance, better engine cooling, and additional vehicle power.
To control radiator fan operation, the PCM looks at inputs from:
Engine coolant temperature
A/C pressure transducer
Ambient temperature
Vehicle speed
Transmission oil temperature (automatic transmission only
HENCE CHECK THE PCM
Jun 26, 2011 | 2003 Chrysler PT Cruiser
Carrier Thermostat aci/10k-an-rso push button, function?.
Most Carrier or totalline tstats have reset button that reset the tstat. Rus
Nov 06, 2009 | Carrier Heating & Cooling
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Freezer fan surges up and down
Don't worry, that is a variable speed DC fan motor. Fan speed is regulated by the mother board as needed.
Oct 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan speed setting of my Carrier furnace model 58wav091-14
most time, you don't have to do anything because the default setting for wiring with fan speed already. if not, trace the motor wires from motor with red , white and black from motor fan to PL2 and PL1. the best is look at a diagram from your actual furnace.
Sep 29, 2008 | Haier HWR06XC5 Wall/Window Air Conditioner
Sunbeam SCA103RWB1 Room Air Conditioner Logo
367 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
