Question about Belkin (F5D7231-4) Wireless Router
Entered a code to laptop from blackberry, and now belkin rounter not working
    President:
  • 1,768 Answers
Reset the router to default and go through the wizard to add and allow devices . use the 192.168.0.1 to get to the admin page and use the setup wizard.
Posted on Aug 07, 2010
Where do i enter password to get wifi on my blackberry off home router?
Welcome to Fixya. To connect you Blackberry to the Belkin router wirelessly you first need to know the SSID or Network Name and the Network Key or Password
- To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank.
- Click on Encryption, You will see there the Network Key or Passphrase. You can personalize the Network Key then confirm the changes try your Blackberry to connect.
- Make sure you connect to your SSID and enter the personalize network key. Network key serves as a password on the network so that no one can access the internet unless they know the password.
Thanks for using Fixya.
Feb 28, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The belkin rounter of my dad's laptop was installed without password setting. i tried to set it up on 192.168.2.1 configuration page. i was notified that the rounter will restart again itself...thereafter...
If you can still remember the password that you entered on the configuration page, follow the steps below:
1. In the lower right corner of your screen (near the time and date), right click on the wireless network connection icon, then select view available wireless networks. Or, if your wireless adapter has its own wireless utility, you should see that in the lower right corner of your screen.
2. You should see the router's wireless network name (SSID). By default, the SSID is "belkin54g". Select the SSID and it will prompt you for the network key.
3. The network key is the password that you entered on the router configuration page.
If you cannot remember the password that you entered, follow the steps below.
a. Connect your computer to the router using an ethernet cable.
b. Access the setup page by typing 192.168.2.1 in the address bar.
c. Go to Wireless -> Security. Copy the network key.
d. Then follow steps 1-4 above.
For the MAC computer:
1. From the Airport menu, select the SSID.
4. When asked for a password, enter the network key that you entered on the router.
I hope this helps!
Jun 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
WD My BOOK 1 TB only shows 20 mb when connected through Belkin N+ wireless rounter. I have a WD 1 TB which is FAT32 and works fine when connected directly to my WIN 7 laptop. But when I connect it to a...
The problems you are having is that 32 bit addressing will only provide a maximum volume size of 20Gb. If you can reformat, you’re NAS device as NTFS this may help.
Feb 07, 2010 | Belkin N1 Vision Router
Change the IP address
There are a couple of things you could have done. Did you turn DHCP off? Are you just trying to use this as a WAP? The easiest thing to do is plug your computer into one of the ports on the Belkin, and nothing into the LAN port, do an IPCONFIG release and an IPCONFIG renew and let the computer get a new IP address. Then try logging into the gateway address displayed.
If you're doing a WAP, set an SSID, set the IP address to your 235 and gateway to 1, turn off DHCP, or let it pass through, because you're going to let the Linksys give out all IP's, then plug the linking cable into network, NOT USING THE WAN port. From the network, you should be able to ping 192.168.1.235 if you can, point your browser to that address and see if you can now log into the Belkin.
If you run into trouble, comment back and I might actually download the manual :-)
Carl
Nov 07, 2009 | Belkin F5D7234-4 Router
Belkin wireless will no longer work with xbox or 360
You need to open the ports that the xbox and PSP uses to connect to the internet in your router. Contact your Router's support and ask them to open the ports in the router for you so that you can connect your game and go online. this is issue with port being blocked.
Sep 06, 2009 | Belkin F5D8236-4 Router
My belkon g plus rounter is not connecting to my new laptop dell but it is connecting to all the other laptops and pcs in the house and i asked my mates father and he said there was code does anyone know...
Code? Do you have any network security enabled? like WPA or WPE? If you do, you'll need a network key in order for you to connect, and you can find that by accesing the adminstrative console of your router, usually, at address http://192.169.2.1. and I am sure you meant 'Belkin' right?
Jun 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
I need help on trying to get my wireless router to work right . it is not working like it should on my lap top . for the wireless net . so what do i need to do .
dear sir
u have to chek internet connection and rounter settung set yr rounter to DHCP mode and configar yr internet in to router after configar yr laptop need to find yr rounter for that u need to run surch wizard it's automatioc found yr rounter then just pair it it's help u..:)
thanks
please vote
chinmay
Jan 06, 2009 | Computers & Internet
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
Conecting to wii
Let me understand you cant access the internet through the belkin router?
Do you know the ip address of the router?
What model belkin is it?
Jun 07, 2008 | Belkin (F5D5231-4) Router
Belkin (F5D7231-4) Wireless Router Logo
22 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
