Question about Indesit 24 in. IDL500 Built-In Dishwasher
Not getting enough water into dishwasher. element glows red hot and arms do not spin
Joe_Rex
  • 114 Answers
SOURCE: dishwasher problems
TURN POWER TO OFF ... REMOVE THE LOWER RACK. THE SPINNING SPRAY BAR USUALLY WILL LIFT SRAIGHT-UP AND OUT ... INSPECT TO SEE IF ANY THING IS IN THERE TO PREVENT IT FROM SPINING FREELY ... THEY SPIN BY WATER PRESSURE SO THE NEXT THING TO CHECK IS THE WATER SUPPLY VALVE (MOST OF THE TIME IT IS RIGHT UNDER YOUR SINK.) AND THE STARAINER is LOCATED WHERE IT CONECTS TO THE DISH WASHER. MAKE SURE YOU HAVE A BUCKET AND RAGS HANDY FOR SPILLS... CAREFULLY TURN THE VALVE OFF AND REMOVE THE COMPRESSION FITTING NUT THAT IS ON THE "SIDE CLOSEST TO THE WASHER".... THEN CRACK THE VALVE OPEN AND FILL THE BUCKET UP A FEW TIMES TO ENSURE GOOD WATER FLOW. TURN VALVE "OFF" AND GO TO WERE THE LINE OR HOSE CONNECTS TO THE WASHER. REMOVE THE CONNECTION ... INSIDE YOU SHOULD FIND A STRAINER THAT MAYBE CLOGGED UP. CLEAN-IT AND MAKE SURE TO TIGHTEN ALL THE CONNECTIONS BEFORE STARTING A TRIAL RUN. NOTE: THERE IS A SOLENOID INSIDE THE MACHINE THAT CAN STICK AND GET CLOGGED BUT USUALLY ITS THE VALVE OR THE STRAINER. GOOD LUCK AND STAY DRY ... Joe_Rex
Posted on May 01, 2007
kermit854
  • 38 Answers
SOURCE: dishes don't get clean. soap
Water from the wash arms must be able to reach the detergent cup during the wash. It sounds as though the machine may be over-loaded during the wash and water does not cause the detergent to mix with the wash tank water. Try washing a cycle with nothing in the machine. Does the detergent still stick to the door?
If no, the machine is overloaded. Wash fewer items or smaller items so spray will contact detergent.
If yes, you have probably lost wash pressure. Clean all screens and jets.
Hope this helps,
Kermit
Posted on Aug 19, 2008
SOURCE: I have a Frigidaire Ultra
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Posted on Dec 14, 2008
SOURCE: Dishwasher
A08 is a problem of the mother board , i changed this and i paid 130.000 for a **** ten minutes of work but i didn't resolve the problem. i waiting for another mother board.
Posted on Jan 05, 2009
SOURCE: middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
Posted on Jan 08, 2009
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Our frigidaire dishwasher is not washing our dishes. The water isn't getting hot enough. Any thoughts?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2011 | Frigidaire Dishwashers
Even though I turned up the thermostat on my hot water heater, the water in the dishwasher does not seem to be hot enough. Mold is growing in the food grinder and even though I choose the heat dry option,...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Oct 25, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Oct 10, 2010 | Dishwashers
PDW9280N20SS Dish's are not being clean
heatman101
Apr 25, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Run times are long and water is not getting hot
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
256re
Apr 14, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwaher water does not get hot enough
heatman101
iueyj
May 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Poor Cleaning and getting worse
A common cause of poor washing is improper loading—dishes block or impede the spray arms or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with washing, the problem may not be your dishwasher. Your home's water pressure may be too low, the water may be too hard, you may not be using the right amount of detergent, or the water temperature may not be hot enough
Apr 29, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Hotpoint hda3700g00bb water not heating
heatman101
e1
Jan 27, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Indesit 24 in. IDL500 Built-In Dishwasher Logo
1,050 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Marvin
Marvin
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
