Question about Cell Phones
Why is the green light flashing on the base unit?
I just found out this is the LED light indicator. I turned it off in Settings on our Blackberry Curve.
Posted on Oct 30, 2010
Flashing green light on base unit BT Studio 3500
The flashing green light is the in use indicator on the base. Click the scroll button down on the handset to show the call list, then press the x or secrecy button, then press the tick or menu but to confirm, the call list is now empty and the green light has stopped flashing, You need to repeat this for each handset until complete
Oct 11, 2009 | Dual Lands Phones
Is it compatible with an IPCC nortel network phone?
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
Jun 02, 2009 | Plantronics CS60 Wireless Headset
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
GREEN LIGHT ON BASE UNIT WON'T STOP FLASHING.
check the dial tone is not set to pulse also delete any messages from bt 1571 and the light will stop flashing
May 11, 2009 | Lands Phones
Cs55 connects but has no sound on headset
The compatibility setting, in almost 100% of the cases, should be set to "1".  You can find it on the side of the base, it's a little turn wheel that will turn if you stick your thumbnail in it and twist.  I have seen one instance on the Cisco IP phones that requires the compatibility setting to be on 5, so try that as well.
If you have a lifter installed, make sure that the short telephone cable that comes out of the back of the headset's base unit is plugged into the handset port of the telephone (where the handset coily cord is normally plugged into).  You would then plug the handset coily cord into the front of the headset base unit.  Make sure you have that configuration, and try again.
Finally you can try a re-set.  To do this you should lift the headset off of the charging base, make sure the green light on the top of the base is off (the headset is off), and then do the following: 1. Hold down the mute button and the call answer button at the same time. (The mute button is the black little wheel on the top of the headset itself.  If you use the tip of your finger to push that straight in, it will mute the headset) 2.  Keep holding both buttons down until the green light below your thumb on the headset flashes for 2 consecutive series. 3.  Let go.  Wait about 20 seconds then try answering.
If this doesn't work, try a re-subscription: 1. Place the headset back on the charging base. 2. The two microphone volume adjust buttons on the back of the BASE unit should be pressed together.  This will start the red light and the yellow light blinking on the front of the base unit. 3. Hold the mute button down while the headset is still on the charging base.  Hold it down until the red light stops blinking. 4. Disconnect the power to the base so that the red light and yellow light turns off. 5. Plug the power back in after about 5 seconds of it being disconnected and make sure the red light on the front of the charging base is now solid and the yellow light is flashing. 6.  Pick up the headset and try again.
May 07, 2009 | Plantronics CS55 Wireless Headset
Headset compatability
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
Apr 22, 2009 | Comdial 8012S-GT Corded Phone
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
To Re-Subscribe:
Jan 12, 2009 | Plantronics CS55/HL10 Wireless Office...
My GE instajack is not working. It had a greeen signal, now it has a red signal.
Most likely, the extension unit cannot communicate with the
indicator light is solid base unit for one of the following reasons:
red • Base unit has yet to be installed. Install base unit. (Refer to
the Set Up section.)
• Extension is too far from the base unit. Relocate either the
base or extension unit to another electrical outlet. If
indicator light on extension
unit remains solid red, reprogram the link code on extension
unit
Follow these steps:
• Press and hold the button on the right side of the base
unit until the indicator light changes to solid red.
(Approximately five seconds.)
• Release the button, then the indicator light will blink orange.
This creates a new link code and places the base unit into
program mode.
• Follow steps (2) and (3) in the Additional Extension Units
section for all extension units.
• Press and release the button on the base unit to take it out of
program mode. The indicator light will change from flashing
orange to solid green.
Oct 10, 2008 | Computers & Internet
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
