I have a pair of comtrend adapters powergrid 902 and on the b unit there is a red light that comes on which is the ap/stby when i press tho on button all the lights go off please can you help
3 Suggested Answers
multilinkent
  • 739 Answers
SOURCE: Comtrend 9020 connection problem Unable to
Hi..
look at the problem you describe. Internet activity is most likely normal, but can not send a good Powerline Standard or High Definition (HD) movies
I said like that because the red led error is when the connection is less than 4Mbps, normal Internet activity Powerline possible but can not send good films Standard or High Definition (HD) movie
see in the picture below
try to do reset to default again
ways to do factory reset
Download manual guide for your reference
CLICK HERE TO DOWNLOAD
regards
hope this will help you
Posted on Apr 02, 2011
SOURCE: I have a pair
I don't have those particular ones, but I have added more units to an existing pair of powerline adaptors. They are not paired, but simply configured onto the network you have set up. Once you have the initial pair set up it should be possible to add as many others individually as you need.
hope ths helps...
Posted on May 16, 2011
I have a pair of Comtrend 8902 which have been working well for a couple of years. However, as of last Saturday, the AP LEDs are all flashing red. Holding down the standby button does stop the flashing,...
hope ths helps...
May 16, 2011 | Computers & Internet
I HAVE BT INFINITY BROADBAND - WORKING OK - I AM USING IT NOW VIA ETHERNET CABLE TO LAPTOP. HAD COMTREND POWERLINE 902 NETWORK SET UP AND WORKING. WAS ABLE TO ADD 2 MORE ADAPTERS - OK. BOUGHT 2 MORE AND...
The modem is probably still looking for the MAC address of your laptop at this point.
You need to unplug the modem AND the 902.
Power up the modem first and give it a minute to let the lights settle then power up the 902
Once the 902 is powered up and it's lights have settled down, start powering up devices that connect to the 902.
You may be surprised that this is all it takes!
Mar 12, 2011 | Comtrend Computers & Internet
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Can not turn my comtrend powerline adapter of standby
i have the same problem,and i'm working on it,most probably a faulty capacitor in the power supply,i will let you know.
Feb 18, 2010 | Computers & Internet
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Comtrend ct507 no power
- try to use a known working power adapter with the same specs, it might be the power adapter is not supplying enough power, or
- try to press the reset button (if it has one) for like 30 secs, then turn the device off for another 30 secs. (Note: this might delete all the settings on the device)
- most probably the device is dead if same thing happens after pressing the reset button.
hope this'll help you
Jun 08, 2008 | Comtrend CT-507 Router
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Computers & Internet Logo
848 people viewed this question
Alun Cox
David Payne
David Payne
